Indexing Plate Question
Home › Forums › Beginners questions › Indexing Plate Question
  • #277779
    john dakin
      @johndakin59277
      I'm new to all this and could do with some advice in laymans terms, I'm trying to make an indexing plate that is 160mm in diameter and I need to put 360 1mm holes on the first outer index, is there some sort of formula to work out if they will all fit without the holes overlapping and breaking in to each other
      #8497
      john dakin
        @johndakin59277
        #277780
        john dakin
          @johndakin59277
          I forgot to mention I'm using a cnc router and cambam for the design
          #277783
          Anonymous
            Posted by john dakin on 14/01/2017 20:17:17:
            …..I'm trying to make an indexing plate that is 160mm in diameter and I need to put 360 1mm holes on the first outer index, is there some sort of formula to work out if they will all fit without the holes overlapping and breaking in to each other
            Yes, but there's not enough information to be able to use it. One needs to know the diameter on which the holes are placed, not the outside diameter of the plate.
            In practical terms no the holes won't break into each other, but the gap between them won't be large ~0.4mm.
            #277784
              Say your ring of holes will be 150mm dia.
              Multiply the dia by Pi which is 3.142 then deduct your number of holes x their dia
              so
              150 x 3.142 less 360 x 1
              471 -360 = 111
              so you have 111mm to spare giving approx 0.3mm between holes, I would use a stub length split point drill so it does not wander and is self starting
              #277790
              john dakin
                @johndakin59277
                Thanks for that guys you have saved the day for me
                #277791
                john dakin
                  @johndakin59277
                  The diameter on which the holes will be placed is 156.5mm
                  #277793
                  Anonymous
                    In which case you'll have ~0.366mm between holes. thumbs up
                    #277854
                    Ian S C
                      @iansc
                      If you want more space between holes you could make a plate with two rows of holes(say 5 mm apart), with 180 holes in each row with the holes staggered.
                      Ian S C
