HSS Tin End Mills
HSS Tin End Mills
Home › Forums › Beginners questions › HSS Tin End Mills
  • #289228
    BOB BLACKSHAW 1
      @bobblackshaw1
      I have several Hss Tin coated end mills purchased from a UK company, I have not had good results when using them. The edges of the end mills look unfinished when having a close look, rather rough edge. I have tried them on steel and aluminium but they seem to rub rather than cut. I have a Osbourne cutter from the 1970s and this cuts well. I also have the e-bay cutters from China which are cheap and on aluminum they are very good. What am I doing incorrect on these Hss Tin cutters.
      #8618
      BOB BLACKSHAW 1
        @bobblackshaw1
        #289231
        Emgee
          @emgee
          Hi Bob
          Certainly something wrong if the flute cutting edge is rough, you will never achieve a good finish with such a tool. You don't mention the cost so maybe they are bottom of the market cutters, you say you have several so if they are all the same rough cutting edges send them back or accept them as roughing tools, get some more from a known reliable source for finishing.
          Emgee
          #289233
          Jon Gibbs
            @jongibbs59756
            Hi Bob,
            I bought a bargain basement lot of metric TiN coated HSS milling cutters and they were similar to the ones you describe. I ended up resharpening the tips and now they cut ok but as they were delivered they had insufficient clearance from my observations. Luckily the HSS was ok (M2) it was just the grind.
            HTH
            Jon
            #289245
            Russell Eberhardt
              @russelleberhardt48058
              TiN coated milling cutters are effective. I would leave Tin coated cutters well alone wink
              Russell
              #289246
              Jon Gibbs
                @jongibbs59756
                Posted by Russell Eberhardt on 17/03/2017 14:40:58:
                Russell
                It took me two read throughs to get there but +1 for that
