If the piston is operated by a lever pivoted in the middle:
pressure in PSI = (pounds you pull on lever * pivot to pulling point on lever distance) / (area of pump ram in square inches * pivot to ram distance)
If you use kilograms and square millimetres, divide by 100 to get an answer in Bars
These aren't exact answers but will get you pretty close.
