No point in complaining or sending it back, looks like its perfectly within spec for rolled SS bar.
on 10×40 thickness can be +/- 0.5mm, width +/-1.0mm and +/- 0.5mm out of section
Just look at google images for "stainless steel flat bar" all rounded corners
If the OP did not specify a perpose or spec there is not much chance of sending it back as not fit!!
Flat rolled bar specs
Ian, you don't say what grade of stainless it is but I suspect its 304 which is often used for forming and welding and general fabrication work, you probably would have been better geting 303 which is more suitable for machining and a bit of Google searching shows it is available fit for your purpose, from one suppliers site:
"303 stainless is used for applications that require lots of machining. All of our stainless 303 flats we stock are cold finished so the edges are square with a true flatness across the flats"
J
Edited By JasonB on 07/12/2013 13:27:28
