Posted by vintage engineer on 12/01/2019 20:41:22:
I would drill a hole down one side and use a bandsaw to cut out a 3" billet then bore the rest out.
Not saying it couldn’t be done, however i once made a pair of motorcycle fork yokes from 1 -3/4” ally plate and used a bandsaw to rough them out, straight cuts ………it was slow and hard going, tried dry at first, but then used WD40 and eventually paraffin as a lube, but even then the blade clogged constantly, wouldn’t fancy the job through 6” on such a tight radius.
