Hints and tips for cutting small(ish) male threads with a die
Home Forums Beginners questions Hints and tips for cutting small(ish) male threads with a die
  • #428908
    David George 1
      @davidgeorge1
      Hi again Stuart. To make the centre screw, just grind or turn a point on the grub screw it is about 30 degrees and you should see the gap open when screwed in.
      Best wishes
      Paul M
        @paulm98238
        I recently had a similar problem trying to cut M3 and 5BA threads with a die. I used the tailstock barrel to butt the holder up to the work as I have done many times. The resulting threads were way off and binned.
        The problem seemed to be with the 3 jaw chuck and the material not running concentrically.
        I turned part of a length of ¼" bar to 3mm diameter in the same chuck and then cut perfect threads.
        Serves me right for being lazy and not fitting my collet chuck!
        #428916
        Martin Cargill
          @martincargill50290
          One trick that nobody has mentioned is to make the piece you are threading slightly too long (too long by the thickness of the die). Then turn this section down to the root diameter of the thread being cut. This acts as a guide for holding the die straight when starting to cut the thread. It works when cutting threads in the vice as well. When your finished just cut the extra piece off.
          MC
          #428922
          IanT
            @iant
            Posted by Brian G on 14/09/2019 08:09:00:
            Posted by Howard Lewis on 13/09/2019 23:44:20:
            …Lubrication with Trefolex , Rocol RTD or something similar is taken as read…
            Having had a 40 year gap I am still using tallow (not the same batch), and I probably have enough to last me out. Is it worth me switching to one of the newer compounds or tapping fluid?
            Before my lifetimes supply of Trefolex arrived Brian, I tried various alternatives. One of them which worked quite well was bacon fat – garnered after breakfast from the grill. It did go "off" after a few days and start to smell a bit but it was much better than dry cutting. Because of the pong it was also necessary to clean everything very well afterwards.
            However Trefolex is a marked improvement..
            Btw – although I use a cutting oil on my large drill press (& mostly drill holes from 3mm up) – on my smaller 1/4" drill (mostly 1-3mm holes) which is indoors, I use Trefolex instead. It seems to work just as well, it is easy to wipe just a little on the drill bit and it doesn't drip on the floor!
            IanT
            #429076
            Stuart Bridger
              @stuartbridger82290
              Bit of time in the shop today, initial conclusiion is that the issue was a dodgy die.
              Brand new split die from Tracy Tools, stock turned to dead on size, no lead in taper, Trefolex.
              Thread cut under power with no issues at all.
