Hello Hopper,
It is certainly a piece of history, but I doubt that many people would bother with it! The bearings are ball bearings top and bottom of the main shaft. Each with a thrust race running on the bottom of the bearing housing. I at first thought they actually ran on the bottom cage lip of the ball bearing, until I cleared the accumulated gunge of old grease. Surprisingly the bearings were in good condition.
The top speed is 10,000 rpm. I now know that there were two three step pulleys for the 3 phase motor. The high speed one is missing and I will need to turn up a replacement. It is too big a diameter for my ML10, so it will have to wait until I finish a lathe refurb, or lock down finishes, so I can use a friends bigger lathe.
I doubt it will get much use, but it has been under my bench for 30 years and I thought it about time I did something with it. Once reassembled I will need my engine hoist to shift it, I guess it weighs at least 100 kilos and maybe quite a bit more!
Andrew.
