Hex file?
Hex file?
Home › Forums › General Questions › Hex file?
  • #23657
    Chris Denton
      @chrisdenton53037
      #174824
      Chris Denton
        @chrisdenton53037
        Morning, I need to slightly increase the size of a 5mm allen key hole on some parts. I think I've seen a hexagonal file somewhere which was meant to do this job, but can't find it now / remember what it was called?!
        It's a through hole.
        Thanks.
        Edited By Chris Denton on 05/01/2015 12:31:49
        #174828
        Jon
          @jon
          I have had a look and cant find any hex files. Last place of work I never came across any and we had many weird and wonderful specimens.
          Just put a flat pillar file down the hole and file each flat in rotation.
          #174839
          Les Jones 1
            @lesjones1
            Hi Chris,
            Are you sure you didn't misinterptret then term "Hex file" (As I did but the opposite way round when I saw the title of your thread.) and assume it was referring to a file to cut metal ?
            Les.
            #174841
              Or are you thinking of these: hexagon-broaches
              P.S. the 5mm one is a snip at £243…
              Edited By Neil Wyatt on 05/01/2015 15:29:50
              #174843
              Speedy Builder5
                @speedybuilder5
                Sounds like you need one of them hexagon drills (again).
                BobH
                #174845
                Speedy Builder5
                  @speedybuilder5
                  These may be what you are looking for, but I bet you won't like the price – perhaps ask for a sample if your German is up to it.
                  Look at the Losenge shape. This is not Hex, but it looks like a 120 degree angle – they come in boxes of 10!! – share them with your friends perhaps??
                  BobH
                  #174846
                  Speedy Builder5
                    @speedybuilder5
                    Make it easy on yourself and click on the English tab – Sorry, I did not see that at first.
                    #174855
                    mick
                      @mick65121
                      Try using a three square swiss file and cut one face of the hexagon at a time.
                      #174857
                      Howi
                        @howi
                        Hex file I am used to –
                        001 10 DE 3A 17 34 07 BB 00
                        002 24 6F FE 11 D5 FF 00 BD
                        #174861
                        Bodgit Fixit and Run
                          @bodgitfixitandrun
                          I too thought it was a computer file. They give really nice edges to a sharp contrast monitor. devil
                          I would just use a good old fashioned needle file and be done with it.
                          #175149
                          Chris Denton
                            @chrisdenton53037
                            Thanks for the replies, I just used a needle file in the end!
