Hi,
I think it is probably the case you can easily find tooling, my initial guess is its BT30. However it would be nice to get a picture with a different angle as I can not make out the drive dog cut outs, or the profile of the area which the tool changer clamps on and off. If you have the tool to hand and do a web search you can check the basic dimensions to be 100%.
SK — roughly translates as Short Taper which is a European description for the self releasing milling machine spindle taper standard that we know as NMTB (National Machine Tool Builders) taper family. Basically it is a 24/7 taper defined in the USA in the 1920's.
The number 30 denotes the size of the tooling. There are various standards and 30 40 and 50 are the most common. 30 is very common and getting 30 taper tooling in all its variations is not a problem. 40 taper seems to be the cheapest new as I suspect it is the most commonly made these days.
There are many variations of this basic 24/7 taper tooling and you need to get the correct variation to ensure compatibility. In your picture the tool has a pull stud which is common in CNC machines for tool retention in the spindle and the flange is suited to a tool changer carousel so from that we can infer it is probably either BT30 or CAT30. BT is common in Europe and is defined using metric, i.e. the thread for the pull stud is M12 on BT30 metric.BT30 spindles have symmetric drive dog arrangement so the cut outs in the tool flange are symmetric.
http://www.tools-n-gizmos.com/specs/Tapers.html
Good luck
Steve
EDIT Jason beat me to it.
Edited By SteveI on 05/09/2017 07:29:53
Edited By SteveI on 05/09/2017 07:40:11
