Thanks for all the advice and the supplier links. I started to look at the difference between ISO 68 hydraulic oil and ISO 68 gear oil. I must admit I have been thinking ISO 68 is a hydraulic oil. I gather it is more of a viscosity grading system. I ended up on a lubricant manufacturer’s website. A young lady adviser asked if I needed help. I asked her wether it was okay to use hydraulic oil in a lathe gearbox. She stated hydraulic…oil is for hydraulic’s and gear oil is for gearboxes!
Armed with this new knowledge I had a rethink!
As far as I can tell the ISO 32 I already bought will be okay for the auto oiler on the Gate mill, so will use that for that purpose and possibly the lathe headstock. I bought 20 litres of ISO 68 locally this morning which I will use for the lathe gearboxes and will have plenty to flush the sludge from the gearboxes first (there was plenty of sludge in the apron gearbox).
Thanks for the links to suppliers of smaller quantities but needed to buy locally as holding up the lathe rebuild.
I was encouraged to see your industrial machine specified ISO 68 hydraulic oil Andrew. In the Grizzly Lathe manual it just says ISO 68 oil so I am not sure wether they are referring to hydraulic oil?
Thanks again to all who took the time to reply, great help as always.
Graham
