Help wanted to find article.
Home Forums General Questions Help wanted to find article.
  • #241677
    Major Disaster
      @majordisaster
      I am looking for an article in MEW concerning the conversion of a mill/drill to power feed using a car wiper motor. I regret I don't know the author. I think it may have been in the last three years.
      I have gone through my large stack of MEW (no, 2 to date) and index but cannot find it. I did find a two part article concerning wiper motor power feed to a Myford lead screw and which was useful, but not the particular one I wanted.
      Can anyone help, please?
      #24583
      Major Disaster
        @majordisaster
        #241694
          According to the index … Issue 201, April 2013 looks promising
            Michael, thats not a wiper mopor one.
            Think there have been posts on here with wiper motors.
            Edit first hit searching this website and this thread gives the issues as 225 & 226
            Edited By JasonB on 06/06/2016 20:46:37
            #241696
              Oh well, at least I tried
              [quote] Rich Wightman's article in MEW 225/226 uses a car windscreen wiper motor for a lathe power feed. dont know
              Edited By Michael Gilligan on 06/06/2016 20:50:08
              #241701
              ASF
                @asf
                Might like to look at these vids?
                #241702
                Steve Pavey
                  @stevepavey65865
                  Not an MEW article, but there is a good Youtube video series on a wiper motor power feed by Stefan Gotteswinter. It has a nice dog clutch drive.
                  Edit I see I'm too late by 2 minutes. But I'm not the only one to appreciate it obviously.
                  Edited By Steve Pavey on 06/06/2016 21:06:21
                  #241705
                  Frances IoM
                    @francesiom58905
                    there was an article on raising a mill by inserting an aluminium block in the column which had an illustration of a wiper motor used to drive the Z-axis lead screw – I raised a query re this on this board – maybe this is the one?
                    http://www.model-engineer.co.uk/forums/postings.asp?th=110523
                    Edited By Frances IoM on 06/06/2016 21:21:06
                    #241723
                    Robbo
                      @robbo
                      For starters have a look at MEWs nos 96 and 152.
                      There are others but I can't bring them to mind. Have a look tomorrow.
                      #241778
                      Robbo
                        @robbo
                        Have had a look through my files and here are some more I couldn't remember yesterday
                        (Note: "Files" = big pile of loose A4 sheets in a wire basket)
                        You are probably thinking of MEW no 201, which was 2 years ago, but this doesn't use a wiper motor.
                        My favourite is in MEW no 50, uses a wiper motor, have seen it in use.
                        One for a Naerok in nos 113/114, but doesn't use wiper motor (cheapo off ebay instead)
                        The most elegant solution is from Dave Machin in MEW nos 14/15.
                        #241975
                        Major Disaster
                          @majordisaster
                          I must thank you all for your efforts on my behalf and apologise to you all.
                          I had read Rich Wightman's articles (MEW 225-226) and Peter Wilton's article (MEW 201). My befuddled 73 year old brain had 'logged' parts of both items and I think I made a composite article of both.
                          My research had taken place over many weeks, interspersed with may letters to and from HMRC, in itself capable of befuddling anyone's brain. Still, I won that one with £25 compensation into the bargain. Should get me a wiper motor at a breakers.
                          Particular thanks to ASF for the German links. His workshop is cleaner and tidier than my dining room.
                          Thanks again, all.
                          #241993
                          john fletcher 1
                            @johnfletcher1
                            Be careful which wind screen wiper motor you buy, as not all are designed to be reversed. An down window wiper motor is more than adequate and all are designed to go up and down. David Machin did an article in an early MEW on such a project, he included a circuit diagram of a speed controller which is very easy to construct. John
                            #242003
                            Muzzer
                              @muzzer
                              Here's one I did earlier. 24V window winder, 0-30V PSU (something like this), toggle switch to reverse direction, wing nut for quick removal etc.
