Help needed
Help needed
Home Forums Model Engineer & Workshop Help needed
  • #38397
    John Weight
      @johnweight34532
      Magazine Article
      #284999
      John Weight
        @johnweight34532
        Good morning all, I am looking for an article by Michael Cox published recently concerning a device to apply forward movement to a drill grinding jig. I think I have gone "article blind" as a search of all my recent copies of M.E. & M.E.W have proven to be unsuccessful. If anyone is able to point me in the right direction I shall be most grateful. John. P. S how does one move down a line on this site?, Thanks, John.
        #285005
          Was it his grinder article in MEW 247?
          Enter key? Or are you using an iphone?
          #285017
          John Weight
            @johnweight34532
            Hi Neil, Thanks for your reply, I have now found the article it was in the February No..251 issue. Can't understand how I couldn't see it. Far too many Birthdays I suspect. Re starting a new line one line lower e.g for a new paragraph the enter key just takes me back to the start.
            Ha, I've sussed it out I think a space after the last letter or full stop is first needed, before using the return key. I​'m using Windows 10 on a desktop, Incidentally M.E.W is an excellent mag. congratulations and many thanks for your help.
              Posted by John Weight on 19/02/2017 15:52:21:
              That's very odd! I use w10 and have never had any problems!
              Thanks for your 'positive feedback'
              mechman48
                @mechman48
                The same with mine if I press enter …goes straight back to beginning of paragraph… what I have to do is press the shift key then enter & it will drop to a new line, … only on this forum tho', anywhere else or in a word doc. it goes as expected…? at the end of the day W10 does what it wants when it wants.
                George.
                #285174
                  Which browser are you using?
                  I use Firefox, are you using Edge or Internet Explorer? If so, try compatibility mode.
                  Grizzly bear
                    @grizzlybear
                    Down arrow, works for me. Win10 I.E.
                    Bear.
