Help about lagging
Help about lagging
Home › Forums › Beginners questions › Help about lagging
  • #80052
    Springbok
      @springbok
      There was a thread in a forum which I am trying to track down which mentioned a material that you could dampen and mould around the boiler or pipes I should have taken a note of it but as usual did not. I remember it saying builders merchants but went in and someone built like a ***** door said duh (just like homer) end of enquiry.
      So can anyone remember what the material was !!!
      Would help me greatly
      Have a good christmas and new year
      #5803
      Springbok
        @springbok
        please can anyone remember
        #80058
        Anthony Knights
          @anthonyknights16741
          Type “lagging ” into the search this site box at the top of this page and away you go.
          #80061
          Springbok
            @springbok
            Hi Thank you Tony for your input but this is not what I want I am building a 5″g B1 and need a lot of the stuff. As I said this was a material that could be dampened and moulded around boilers and pipes you will note that I am involved with these posts already.
            Bob
            Have a nice one.
            #80065
            John McNamara
              @johnmcnamara74883
              Hi Springbok
              Recently I had to design a domestic fire place and contacted a fire brick supplier. This company also supplied the foundary and furnace industries
              The company had a range of materials for “casting” a fire protective layer…..Some materials were “Air set” while others were heat set. They also had various kinds of matting both flexible and rigid.
              I live in Melbourne Australia so the following link may not help you; but it may assist in helping you where to look. and what to ask for.
              If you search for “Fire brick” in your location you may find another?
              Cheere
              Springbok
                @springbok
                Hi John
                Very helpful gives me some terminolgy to search on.
                Hope weather is nicer in Melbourne than here it is -2
                Bob
                #80081
                Ian S C
                  @iansc
                  There was a thread in genral questions sect of Model Engineer Clearing House a few months back, I think it was about a Tich built by Paul? I think, that might set you in the right direction, it was some sort of hi-tech paper.
                  Ian S C
                  #80095
                  Robert Dodds
                    @robertdodds43397
                    Hi Springbok,
                    Have a look at Vermiculite cement.
                    A 6:1 mix with portland cement is used as an insulating filler in firebacks.
                    Depending on your thick ness you might need to mod the ratio but vermiculite is on ebay and should be in DIY and garden centres as it also doubles as a soil lightener.
                    On ebay there is also ready made thin board which might suit your needs
                    Good hunting
                    Bob D
                    #80107
                    Blue Peter
                      @bluepeter
                      Springbok
                      Kaowool Blanket or Kaowool paper is the stuff that is usually recomended which should be available from builders merchants or insulation specialists, but I don’t know how big the pack size is. Blackgates list it in their catalogue per square foot.
                      Weldaguard from insulation specialists is another option.
                      There’s also carboard from cereal packets built up to thickness.
                      Peter
                      #80109
                      michael howarth 1
                        @michaelhowarth1
                        Springbok….I am currently experimenting with ceramic fibre and fireclay cements. I have had a bit of success soaking the fibre in the cement mixture and then moulding it to shape. It goes quite stiff and stays in position. Pottery suppliers are the people with good knowledge of this subject. The materials are relatively cheap and the ceramic fibre is available from ME suppliers. Chronos used to do it and Polly I think. If you think that this would be of use to you and want names, leave a PM for me and I will try and sort them out.
                        Mick
                        #80132
                        Tony Martyr
                          @tonymartyr14488
                          I have used exhaust wrap on a track-car and as boiler insulation bought from:
                          #80153
                          Springbok
                            @springbok
                            Mick
                            Sounds like the stuff I read about will send a PM
                            Bob
                            #80162
                            Ian S C
                              @iansc
                              Bob, have a look at Thanks NASA by Paul Denny on page 9 General Chat, Model Engineer Clearing House, worth a look.
                              Ian S C
                              #80166
                              Dave Martin
                                @davemartin29320
                                Not certain if its suitable for your application, but you can get castable insulation in various grades & densities, such as castable vermiculite, rated to 1050 degrees C, at GBP 35 for 1/2 cwt from Kiln linings
                                usual disclaimer – no connection with them other than as a customer
                                Edited By Dave Martin on 20/12/2011 13:34:23
                                #80169
                                michael howarth 1
                                  @michaelhowarth1
                                  Dave…brilliant selection of stuff ….but no contact details that I can find…..only an E mail if you are a company…..and presumably big order.
                                  #80171
                                  Keith Long
                                    @keithlong89920
                                    Hi Mick
                                    Just looked at the site Dave highlighted above as interested in this type of material for a kiln/furnace lining.
                                    Scroll down the page (a long way) until you come to a box on the left hand side headed “Information”. In the box is a heading “Contact us” click on that and you’ll get address info etc.
                                    Looking at the form to register an account there is a box for “Company name” but it ISN’T a “required field” so I don’t see any block to you ordering as an individual.
                                    Keith
                                    #80172
                                    Dave Martin
                                      @davemartin29320
                                      Posted by mick H on 20/12/2011 15:31:39:
                                      Haven’t got a landline phone number for them, I just ordered off their web site. You might get the number from directory enquiries, the address from the web site is
                                      Kilnlinings
                                      53 Ennerdale close
                                      Dronfield
                                      Derbyshire
                                      S18 8PL
                                      but a quick google gave a mobile 07958-615187
                                      well – they start with insulation bricks at 29p each ….
                                      cheers / Dave
                                      Edited By Dave Martin on 20/12/2011 15:46:28
                                      #80178
                                      michael howarth 1
                                        @michaelhowarth1
                                        Thanks gents….time I went to Spoecsavers I think.
                                        Mick
