Grinding Wheel Blotters
Home Forums General Questions Grinding Wheel Blotters
Viewing 3 posts - 26 through 28 (of 28 total)
  • #297120
    Tractor man
      @tractorman
      By the way it is a very comprehensive book and worthy of a slot on your book shelf.
      D.A.Godley
        @d-a-godley
        Posted by terry simpson 1 on 06/05/2017 19:40:33:
        Having the need to remove and remount both grinding wheels on my Tool and Cutter Grinder I find that the manufacturer fitted paper blotter on each wheel has become, shall we say unusable again (knackered otherwise). As it is impossible to buy new paper pads what other materials have our brethren used to soften the compressing forces of the spindle clamping devices on the grinding wheel.
        Have thought about actual blotting paper from the likes of Ryman or Smiths but apparently wet ink as was known is not used nowadays.
        I was actually advised to try some very fine sand to dry the ink as in Dickens time.
        #297214
        D.A.Godley
          @d-a-godley
          Terry, Should you still wish to use blotting paper , I could send you an A4 sized piece or two .
