Green wheels instead of aluminium oxide
Home › Forums › Beginners questions › Green wheels instead of aluminium oxide
  • #310438
    Gareth Jefferson
      @garethjefferson65077
      Since silicon carbide "green" wheels would obviously be hard enough to grind hss, is there any reason why I shouldn't didpense with my aluminium oxide grindstone and use the now free end of my bench grinder for a diamond wheel? I mostly use hss in the lathe and mill but want to start scraping using carbide scrapers. I have a spare bench grinder but bench real estate is running out fast in my small shop.
      — Gareth
      #8821
      Gareth Jefferson
        Using a green wheel for grinding HSS
        #310439
        Ady1
          @ady1
          Green wheels are for carbide and are actually quite soft ?
          The harder Grey oxide wheels do HSS
          That's my basic understanding
          The green stuff is highly sacrificial and produces a lot more dust?
          Discuss!
          #310444
          Thor 🇳🇴
            @thor
            Hi Gareth,
            This post explains why it is normal to use aluminium oxide wheels on HSS and not silicon carbide.
            Thor
            #310451
            Clive Hartland
              @clivehartland94829
              Grinding offhand on a Diamond wheel is a no no. Use it only for final dressing of the edge.
              Take off the bulk with the green wheel. Mount the spare grinder on a wooden block that you can fix in the work bench vice. Make sure you have a rigid support against your diamond wheel as they are soft and it is easy to dig in !
              #310465
              Mark Rand
                @markrand96270
                First off, Aluminium oxide will grind HSS perfectly well. SiC is needed to grind tungsten carbide in the absence of diamond.
                A far softer wheel is needed if one is grinding ordinary mild steel compared with hardended HSS if wheel loading is to be avoided, so consider your grinder usage. Obviously a soft wheel will work with soft and hard materials if one is happy with the rate of wear
                If you want to sharpen scraper blades, think seriously about roughing them out on a SiC wheel or cheap diamond wheel, then using a cast iron wheel (made on whatever lathe you have), with 2-5 micron diamond paste rolled into it..
                #310488
                jaCK Hobson
                  @jackhobson50760
                  I just use a cheap diamond plate and hand-sharpen scrapers. I think you need quite a fine finish.
                  #310678
                  mark costello 1
                    @markcostello1
                    If You use a green wheel to grind steel You will be amazed how fast the green wheel disappears.
