I have bought four(?) second hand Meaco desiccant dehumidifiers over a period of time – all were ‘dead’ as purchased. Total cost was less than a hundred (plus delivery/collection).
First runs quite well on low speed setting as the fault was within the heater element (I removed the offending resistance wire). Everything needed new lubrication as the chinese ‘stuff’ was not grease as we should understand the term!
Second also finished up with a similar heater element (I bought it just thinking I would have a spare heater for the first, should it be necessary).
As I expected to enlarge my workshop, I bought two more scrap machines, but one water tank and filter was missing, so have only finished with three working machines (two in operation and a working spare).
They work brilliantly but clearly they were not one of the most reliable items around. But easy to fix.
I have only needed to run one at a time this winter, although I left both running (at different times on E7) while we were away over Christmas – just so one did not fill the two litre tank and turn off.
If there is any air exchange, damp air from outside will percolate in, there will be moisture from below (unless a damp-proof sheet was laid under the floor) and we breathe out water vapour, so there will always be some water to collect (I leave mine on the ’laundry’ humidity setting and just run for two or three hours at night).
I’m currently collecting about half a litre per night. Not sure if it is running two or three hours. Running costs are either less than 6p or less than 9p per night, I think the former. The heat is likely as important as the humidity reduction.
I expect the innards of the ecoair are much the same as the meaco – possibly built to be more reliable than the early meaco machines, but same principle of a rotating desiccant wheel with desiccant recharging, by blowing hot air through the drying medium in part of the revolution.
I had one good experience with appliances direct – I collected a chest freezer. But since then, they have not quite cut the mustard. I got a better deals for each of the dishwasher, tumble dryer and washing machine from more-local suppliers. One often finds their model numbers are slightly different to the usual brand code for that item – and nobody wants to explain any differences.
