Posted by Nicholas Wheeler 1 on 17/07/2021 10:20:18:
Posted by Circlip on 17/07/2021 09:54:24:
Risk assessment for the simplest daily tasks beggar belief.
Rubbish.
You don't check that the kettle isn't full of boiling water before moving it? That's a risk assessment.
Ensuring that the vacuum cleaner cord can't trip you before you carry it down the stairs? So is that.
How about looking both ways before stepping off a kerb? Guess what? Risk assessment.
Examining the condition of the box of parts before you pull it off a top shelf? R/A
And so on.
Personally, I think the phrase common sense is much, much worse.
So if the kettle is full of boiling water you don't touch it? Must be very dry in your household. I boil a kettle to make coffee so I know (still have a memory) why it would be hot.
I have an upstairs and a downstairs vac BUT in the event of changing floors/rooms I always make sure the leads are retracted or re coiled onto the appliance.
Looking both ways? That was ALWAYS drilled into us when the Ford 10 was in its infancy.
I don't load parts into boxes to put on a top shelf.
"Risk assessment" is one of the yuppy buzz words generated to fill the new Oxford. FMA (Failure mode analysis) is another. I didn't need a Ford Prod eng to tell me "The weld joint on this steering linkage is subject to FMA" COMMON SENSE dictates if it's not a good joint and gives way, it's likely the car will crash and doesn't need three (or more) pages of bovine excreta to qualify this.
Yep Nicholas, C/S is a no no word for the legal profession who make vast amounts of money for those who don't posses it.
Regards Ian
