After reading the book from "The model steam locomotive" by Martin Evans and "Design Procedures for Walschaerts' and Stephensons's valve gears" by Don Ashton, I started to draw my own designed loco in Solid Edge ST6.
That's the first time ever I used a 3D CAD software to draw anything, but I guess my willingness to build a locomotive made me learn how to use the software. My previous skills on (manual) technical drawing were limited to what I learnt during my chemical engineering studies, but I hardly needed them at work. Actually, I never used a professional CAD package before, even a 2D one. So, to be honest I find the Solid Edge software a bit tedious and frustrating at times, though I am sure this is due to my lack of skill than to the software itself.
See below what I achieved so far. My goal is to design a live steam loco that roughly matches the 5" Britannia dimensions but with the following characteristics:
– No importance is attached to the model being an actual replica of a full scale locomotive, but it still should look and be clearly identifiable as a steam locomotive. The loco will have free dimensions.
– Get rid of imperial units in drawings. All dimensions will be in plain millimetres. Parts will have exact measures and will be arranged in ortogonal or horizontal/ vertical planes for as much as possible.
– The assembly will be made of standard industrially available parts where this makes sense and it would deliver an improvement over what is usually used in current designs. For example, I may use lubrication free flat miniature bearings on rods and levers, or lubrication free ceramic bearings on wheel axis. I will use commercially available industrial grade miniature valves, safety valve, regulator, water gauge and so on if possible.
– Stainless steel and aluminium will be extensively and primarily used for all parts, and will be chosen over copper, brass or gunmetal for as much as possible. Technical grade polymer materials will be considered as well. Eventually even the boiler will be evaluated to be built out or AISI 316L steel.
– One objective of the project is that all parts should be carefully 3D drawn in a way that most parts can be automatically build by CNC (computerized numerical control) equipment, or laser/water cut directly out of the drawings, with minimal hand made retooling required if at all.
The video below shows what I came out so far for the valve gear design. I chose a Baker valve gear geometry as opposed to a Walschaerts because it's easier to build and I think it's easier to assemble as well.
In theory getting the correct valve events and timings on a Baker valve gear is a bit tricky, but I guess that after much Solid Edge simulation and the study of the Don Ashton book, I acquired an understanding of the gear so I feel now comfortable with it.
I will come with a ton of questions as my design progresses. So far I would appreciate any comments on what I achieved so far, as well as any visions on my (particular) approach. I hope I am not doing anything totally wrong. I am a total beginner so basically I hope my approach is not totally biased towards the wrong side.
The video shows the loco in forward motion first, then I switch the reverse yoke to backwards, at this time the motion still appears to run forward because the simulator just makes the wheel turn in a specific direction, but in fact the valve events are the correct ones to produce a backward motion.
Here's the video:
http://youtu.be/hzJr6GkfezY
Thanks in advance
Edited By John Lluch on 26/09/2014 22:35:53
Edited By John Lluch on 26/09/2014 22:44:37
