For 18months after the rebuild the engine (Both) of them smoked. I stood by as others did the rebuild and I could not understand the injection system – the tolerance was 1thou, it was all set up with the proper gear. The method used a DTI. De rated pumps, different spray angles, different injector nozzles all to no avail – cost a fortune. Then one day a man turns up and resets the injectors and the smoke is gone – I was right, on a 50yearold engine the only way to set the injectors is with a torque wrench, all the manual info is duff, dti and 1thou Etc. Little bits of wear on the cam, followers, push rods, rockers and shaft all add up to more than 1 thou Not a good start ! The way these engines have been used the problem could be almost anything ! The head gaskets come in 1 thickness ! On engines this size the inlets are 2 manifolds joined by a flexible tube ! On reflection the 400psi is not something to worry about, I had given little thought to adiabatic compression ! I have already found a problem with the injector rocker and these engines were known to drop exhaust valve heads.
On a previous breakdown, one knew it was not good when one finds TWO exhaust valve heads in the manifold ! !!! Piston, liner, little end, oil pump all smashed to bits in the sump, gudgeon pin wedged across a crank throw, 2 LARGE holes in the crank case, even the back plate was broken. Certainly the best wrecked engine I've seen !
The exhaust manifolds have been pressure tested, the electric hoist has been rigged and a blow down test will be done tomorrow. The valve gear seems OK on the low cylinder,The compression was about 150psi, so I'm thinking head gasket blown into a waterway. I will keep you posted. Noel.
