Posted by RRMBK on 03/01/2017 16:09:28:
…. I want to create some small ( 1/2" X1"x 1 " up to about 3 x 3 x6 inch cut outs to safely store some wooden patterns for the long term . I would like to get the foam first and then make the boxes from plywood at a size to suit each batch of patterns.
Plastazote is perfect for this ^^^ sort of job … it cuts cleanly and easily, and layers can be glued together with contact-adhesive … it doesn't degrade to sticky mush like some other foams, and it's closed-cell [so doesn't take-in water].
If the patterns are worth keeping, they are worth the modest investment involved in using good material. … It's used in a lot of military packages [and I've tested a fair few of those].
