First of several
First of several
Home › Forums › Workshop Tools and Tooling › First of several
  • #291441
    peter blair
      @peterblair72074
      Here is the first in a group of tools that I hope you guys can help me identify.
      It was collected in a box of the items from a garage sale.
      It is a sort of razor blade shape but quite thick on the back comes with a small hinged lit tin. The tin is slightly shaped the same as the 'blade'.
      #18467
      peter blair
        @peterblair72074
        Mystery tools
        #291442
        Speedy Builder5
          @speedybuilder5
          It is a blade, in which case it was from a "Rolls Razor" for shaving. I think the script says that, so not too much of a mystery , and the case was for portability. I have seen them as a set of 7, one for each day of the week, and they came with a sharpening machine which was an oil stone on one side and leather strop on the other. The section is much the same as a cut-throat razor, but much (well a little bit) safer.
          BobH
          #291443
            Looks like the spare blade of an early type of safety razor. The razor came in a box with an oilstone. The handle and blade holder are hinged to make sharpening easy. I have one made by Rolls Razor somewhere.
            Cash prizes I hope!
            Doh! Speedy Builder is speedier than me.  Perhaps we could share the prize?
            Edited By SillyOldDuffer on 31/03/2017 14:49:19
            #291445
            John Flack
              @johnflack59079
              Hmmmmmm… It looks like a holder for the old ROLLS(not Royce) blades my dad used to use in his rolls razor.
              If it's hall marked I pass.
              #291567
              peter blair
                @peterblair72074
                Ok so you guys really are good!! I did think it might be razor blade but thought it might have something to do with early drafting or drawing.
                Here's your next test. Almost looks like a 'nibbler' of some sort the metal protruding from the front has a notch but I can's even guess what the two L shaped guides/brackets are . . .
                img_1625.jpgYou guys are GOOD!! I
                #291569
                Bazyle
                  @bazyle
                  The L brackets are just to stop your hand sliding up the handles as you squeeze because the force needed can be quite high. I have a similar one .
                  #291570
                  peter blair
                    @peterblair72074
                    Thanks Bazyle, what is it for?
                    #291571
                    Bazyle
                      @bazyle
                      Well mine is a nibbler. Can't see the top of yours to be sure though. Nowadays I use an electric drill attachment one.
                      #291580
                      Speedy Builder5
                        @speedybuilder5
                        Similar idea on the MONODEX cutter.
                        #291601
                          Mine has 'ergonomic' ribbed plastic handles.
                          #291648
                          peter blair
                            @peterblair72074
                            Ok, sounds like you guys nailed this one as well, but tell me is a notcher and a nibbler the same? I have seen a few nibblers but this one looks like it would take a really small bite and I wondered if it might be for making some sort of small notches?
                            #291649
                            Bazyle
                              @bazyle
                              Some designs are better at going round corners than others but the names are not that specific.
