First cuts with the lathe
Home Forums Beginners questions First cuts with the lathe
Viewing 11 posts - 26 through 36 (of 36 total)
  • #803492
    duncan webster 1
      @duncanwebster1
      Diamond file is good for rounding the vertical edge
      duncan webster 1
        @duncanwebster1
        Diamond file is good for rounding thd vertical edge. 1/4″ sq tools are a lot easier to grind and plenty stiff enough for small cuts whilst learning
        #803497
        jamesp1
          @jamesp1
          On Howard Lewis Said:
          Cutter? Surely lathes have tools and toolbits and milling machines have cutters? The difference being cutters rotate while tools and toolbits remain stationary? (Not sure where that leaves shapers though?)
          While most of us are trying help a newbie, can the above please be moved to pedants corner.
          Pedagogy not pedantry! Teaching a “newbie” incorrect terminology is not helpful in the long run.
          #803546
          Pete
            @pete41194
            While there different lathe brands than yours is Chris, a couple of PDF links for good basic turning information including tool sharpening.
            https://gadgetbuilder.com/How-to-run-a-lathe.pdf
            http://www.opensourcemachinetools.org/archive-manuals/Hercus_TextBook_of_Turning.pdf
            If you have lots of books and don’t yet have this one, put it on your mandatory to buy list. https://www.teepublishing.co.uk/books/in-your-workshop/model-engineers-workshop-manual/ Yes I’d term it as a medium level to sometimes lower advanced level book. But it’s one you’ll refer to often. And even at your current level, a great deal in it that can be used immediately. The authors thoughts about proper slide adjustments, HSS tools, and even the pros and cons of QCTP’s just for starters. I was going back through my own copy this morning in fact.
            As someone has already said in this thread, problem solving is a big part of the hobby. Sometimes highly satisfying, and sometimes extremely frustrating until you finally get a reason and solution figured out. Learn to view any problem using pure logic and think everything through. And not what you think might or should be true. In the beginning it usually isn’t. 😀
            #803549
            Dave S
              @daves59043
              Sherline has a good how to grind tools guide:
              https://www.sherline.com/wp-content/uploads/2015/01/grinding.pdf
              Nigel Graham 2
                @nigelgraham2
                Diamond file –
                Not thought of that – Thanks for the hint, Duncan!
                #803585
                  My old-British books call lathe tools “knives”…
                  History left metal-working terminology in a mess, especially in pioneering Britain, where trades, regions and companies all had their own variations.  Whatever jargon individuals were taught in the past can’t be universally correct because there is no common standard.
                  I think beginners just need to be aware it’s necessary to read between the lines sometimes.  We shouldn’t make it difficult on the forum:  I suggest ‘cutter’ is easier to understand than ‘tool’ because ‘tool’ is ambiguous, whilst “knife” is positively misleading.
                  noel shelley
                    @noelshelley55608
                    DID THE PERSON UNDERSTAND WHAT WAS MEANT BY THE TERM ? Does a lathe tool not cut ? It should ! Noel.
                    #803713
                    Pete
                      @pete41194
                      A lot of the books covering lathe tool sharpening are a bit lacking in details Chris. Too many of them seem to cover the powered grinder sharpening well enough, but neglect or may not even mention the needed honing after. Yes a ground tool right off the grinder will cut, but not nearly as well or with the same surface finish quality as one that’s been properly honed. Paraphrasing George Thomas, “a rough ground tool can not produce a fine finish” or words to that effect. And a well honed tool with a slight tip radius will also last much longer. Many times you don’t even need to regrind the tool, just re-hone it and it’s as good as new.
                      However the term honing is a bit subjective as far as how sharp the tools cutting edges should be. Pulling the tools honed edge with very light pressure down your thumbnail, it should be sharp enough to start to raise a chip is one way. A proper and very good quality stone with a recognizable brand name such as a Norton isn’t cheap. And cheap stones aren’t worth buying. And after enough use, they need to be re-flattened. Instead I chose to buy from a woodworking tool dealer a diamond coated plate. They stay flat, last almost forever, hone quicker and in some cases, are cheaper than a good stone. I also use that plate with a few drops of light weight oil. Something easy to get like 3 n 1 if it’s available in the UK, or sewing machine oil works fine.
                      #803735
                      Martin Kyte
                        @martinkyte99762
                        I use window cleaning fluid with my diamond hone plates. It’s convenient in the spray bottle and less messy than oil. Wipe clean afterwards with kitchen roll.
                        #803737
                        Pete
                          @pete41194
                          Thanks Martin, I’ll have to give that a try.
