filing rest
filing rest
Home › Forums › Workshop Tools and Tooling › filing rest
  • #249034
    mick70
      @mick70
      been offered a filing rest for lathe.
      can't seem to find much info apart from useful for filing flats on rd stock.
      are they useful to have and exactly what are they for?
      it came from myford and will need spacer to fit my lathe but thats not a problem.
      got some money left over from last month so it needs spending.
      cheers
      #18162
      mick70
        @mick70
        #249039
        Ajohnw
          @ajohnw51620
          I'm pretty sure I have seen mention of them being used to file round work parallel even to the extent of a twin roller version being mentioned in ME. – Which I haven't bought for >> than 15 years.
            If you don't have a mill they are used to file square, hex etc flats onto a round bar using simple indexing of the spindle.
            Never seen mention of them being used to file round work parallel and all have twin rollers, one either side of the work so the file stops cutting the work as it runs on the rollers.
            #249048
            Martin Kyte
              @martinkyte99762
              As you say filing flats on round stock. Producing squares. Making D bits.
              I'd say handy but not essential especially if you can transfer stuff to the mill.
              Depends how cheap it is. If you just want to spend money then collets , reamers , taps and dies ?
              regards Martin
              #249049
              Philip Rowe
                @philiprowe13116
                I made my filing rest back in the 70/80s from I think a G.H. Thomas design. To be honest it doesn't get that much use but it is quite useful when putting flats on round stock. On one occasion a triangular head on a bolt that needed to be tamper proof.
                What is suprising is how quickly one can achieve things like this as opposed to removing the stock from the chuck and transferring to the mill, not forgetting all the set up time.
                Phil
                #249054
                Bazyle
                  @bazyle
                  As well as having two rollers to control 'depth of cut it should have shoulders on the rollers to provide a longitudinal end point. Then you have to make sure the safe edge of your file is properly safe not having the thin line of residual teeth form the forming process. You also want to make sure it has good design of height adjustment. Newer designs use the height control of a QCTP.
                  #249058
                  Phil P
                    @philp
                    Posted by JasonB on 02/08/2016 12:08:21:
                    Jason
                    They don't all have twin rollers, in fact the majority of ones for watchmakers lathes only have one roller. I dont see how they can be used with any accuracy or repeatability though.
                    I have just managed to get hold of a twin roller one myself, its main use for me will be "reducing" the size of hexagons on small commercial BA bolts, or making them from scratch using round stock. I think doing each one in the mill might be very time consuming, so I am going to try this method first.
                    Phil
                    #249062
                      I'd not seen the watchmaking ones Phil, as you say sounds lke they will only be as accurate as you can keep the file level.
                      I suppose if you have one of those spin indexers that will just jump to the next index point as you pull the lever it would be quite fast on the mill especially if you cut in both directions, even more so if you have lever feed rather than handwheels. A standard spin indexer would take a while pulling the pin out, rotate, put pin back etc.
                      J
                      #249063
                      Ajohnw
                        @ajohnw51620
                        I had my tongue in my cheek. I am 100% sure I have seen comments about using them to remove taper in round work. They could also clearly be used for final sizing and polishing. As I haven't done either I can't comment on the practicality but given that they are made with sufficient accuracy / adjustability I really can't see why it shouldn't work out.
                        I have also seen designs with one roller as Phil mentioned and not for watch making as well.
                        Ian S C
                          @iansc
                          For forming hex heads on bolts, making nuts, and other simple forms, it's often quicker to file them than set up the mill and rotary table. Ian S Cdsc01000 (640x480).jpg
                          #249078
                          clivel
                            @clivel
                            Probably one of the simplest filing rests that one can make, is something like the one I made for my Unimat a few years ago, based on an idea in another forum.
                            Here are two views. Partly disassembled and assembled.
                            To use it, simply mount it in the lathe toolpost rotated about 30 to 45 degrees from the vertical. The crosslide is then used to adjust the filing depth. This photo of it being used to file a flat on the end of a rod should make it clearer.
                            Although it doesn't get much use, it is handy on occasion, and far faster to set up than setting up the milling attachment.
                            I have subsequently made two changes to it since the photos were taken: I replaced the socket head screws with countersunk screws allowing it to get closer to the chuck, and I also reduced the diameter of the thick washers which hold the rollers on and also act as a stop for the file as they limited the maximum diameter of the work piece.
                            #249098
                            Phil P
                              @philp
                              You have just answered a question for me.
                              I had always wondered why some of the double roller filing rests for watchmakers lathes were designed with the rollers at different heights.
                              The penny has just dropped. Thanks
                              Phil
