Feed Water
Feed Water
Home Forums General Questions Feed Water
Viewing 6 posts - 26 through 31 (of 31 total)
  • #814717
    Richard Simpson
      @richardsimpson88330
      I must admit Dave, in my time at sea I have come across a huge range of many varied and interesting pieces of machinery.  From slow speed cathedral sized engines four decks high to modern medium speed multi engine installations with incredible levels of flexibility and built in redundancy and many things in between.  Building models has led to research and consequently an interest in marine engineering history, that I continue to enjoy.
      Many many memories but possibly the most memorable was controlling a slow speed cathedral engine from the engine platform after the bridge control system failed.  It was a seven cylinder 20,300 shp Sulzer 7RND90 and the buzz of stopping and starting that immense piece of machinery stayed with me.  This is a great shot of one cylinder’s running gear outside the engine manufacturer’s head office:
      9240580488_a169468b82_o
      noel shelley
        @noelshelley55608
        An interesting observation of this type of diesel engine is the use of a crosshead !
        Having investigated the composition of rain water, it very much depends on where you get it from as to how contaminated it will be. Hard water is a bad idea, but using water treatment intended for steel boilers, de ionised water, or rain water, all have their disadvantages,whether these are real or theoretical is the question. Whilst distilled water would seem the best option, cost is the downside.  Noel.
        #814730
        Vic
          @vic
          We have an under sink water filter. We use the water from it in our kettle and also the steamer. Strangely the kettle remains largely limescale free until the filter is about 10 months old and needs replacement, whilst the vegetable steamer still collects limescale on the heater? The only difference I can see is that the kettle is stainless steel and the heater in the steamer is some other type of dull grey metal.
          We have a dehumidifier but don’t generally use the waste water for anything. I read that depending on the exact unit the waste water could contain small amounts of heavy metals as well as other contaminants.
          I use a mixture of filtered tap water and rain water in a fish tank. PH is generally neutral.
          #814743
          parovoz
            @parovoz
            Up here in the ‘frozen north’ boiler feed water is generally not a problem… It just comes out the tap ! For copper boilers, no treatment required, for steel boiler, a commercial standard tannin feed water treatment is fine.
            #814777
            larry phelan 1
              @larryphelan1
              With all this talk about what  gets into water, I,m half afraid to go down to the local for a few pints !
              Can NOTHING be trusted anymore ????
              #814858
              noel shelley
                @noelshelley55608
                Larry. Boil up about 20gals of good strong beer, allow the vapour to come off until until it reaches 90* C, pass through a condenser and drink the resulting liquid, IT will be free of dissolved matter and you will be pickled ! Noel.
