Farm Boy
Farm Boy
Home Forums I/C Engines Farm Boy
Viewing 5 posts - 101 through 105 (of 105 total)
  • #806797
    Dalboy
      @dalboy
      Now down to some serious assembly on the engine. Slowly putting it back together and checking everything as I go.
      This is as far as I have got. The fuel tank still need fixing to the base
      Assembly part 1 (10)
      Assembly part 1 (9)
      Diogenes
        @diogenes
        Lookin’ good, not far to go now..
        #806949
        Dalboy
          @dalboy
          Thank you.
          Main engine assembled and timing and valve clearance set, need to find a spring for the governor balls. Will search through my spring box. As it is, I found a spring for another part and ping it went off on it’s travels never to return, luckily I found another to replace it with.
          Working on a Fuel ordered while waiting for that I can work on the wiring and getting the fuel tank fitted, and a top made as well as an exhaust that will look the part all set up ready to machine that.
          assembly part 2 (1)
          assembly part 2 (2)
          assembly part 2 (4)
          assembly part 2 (5)
          #807243
          Dalboy
            @dalboy
            Another little job today, please give your thoughts on this will it work or is it a try it and see.
            As the plans don’t show an exhaust, just a threaded hole in the head, I thought of making one based on something I have seen around the rally fields.
            There will be a short pipe joining them. As can be seen a little on the small size but any bigger I felt would be out of place.
            The two part before fixing together
            Exhaust (1)Exhaust (6)
            Assembled and cleaned up. £1 coin for scale
            Exhaust (12)Exhaust (15)
            #807260
            Diogenes
              @diogenes
              Probably be okay as long as the slot area is bigger than the valve open area.
              ..it’s quite hard to tell without seeing it up next to the engine, but if you think it looks ‘right’ it probably will be.
              I might do the engine ‘setting-up’ without it at first and once you have a stable runner, see how it sounds and whether it affects the running.
            Home Forums I/C Engines Topics
