Eyesight problems
Eyesight problems
Home › Forums › General Questions › Eyesight problems
Viewing 25 posts - 1 through 25 (of 29 total)
  • #85579
    Windy
      @windy30762
      I am now at an age where my eyesight for close up work can be a problem.
      Examples, vernier reading and welding.
      My spectacles are thick and I have bifocals.
      The optician made me safety glasses with reading lenses in the past but was only reasonably good on a fixed distance.
      With my sight if I remove my spectacles up to about 5 inches from my eye it’s like looking through a magnifying glass and is good for reading fine scales etc.
      My optician said he could make me some reading spectacles to focus at any distance that I require but the image will not be the same size as when my glasses are removed.
      I envisage doing a fair amount of Tig welding and providing it’s bench work can manage without my glasses as I can keep to a fixed distance.
      But when Mig welding awkward parts on car chassis work would have to wear spectacles because of variable distances and spatter.
      I am using an automatic welding helmet now.
      Wondered if varifocals would be any good or is there any spectacles that can give a magnified image over variable distances?
      Windy
      #22020
      Windy
        @windy30762
        #85581
        Stephen Benson
          @stephenbenson75261
          Sounds like you need an Optivisor I would not be with out mine, I have one for close work and one use when I am working on my on my lathes.
          There is a set with all the lenses but it is expensive £100+ there are cheaper options but I have not tried them.
          #85582
          John Haine
            @johnhaine32865
            I wear varifocals and they are a b*****r in the workshop as one is always wanting to look at something close through the top of the lens! Really it would be nice to have upside-down varifocals with close focusing at the top and longer distance (but not very long) at the bottom.
            #85584
            Russell Eberhardt
              @russelleberhardt48058
              Posted by John Haine on 23/02/2012 19:56:34:
              I agree, ever tried rewiring a ceiling rose?
              Russell.
              #85586
              Clive Hartland
                @clivehartland94829
                Interesting point raised here, Bifocal glasses with the Dioptre at the bottom of the lens and you are working looking up with your head back could induce a stroke.
                There are other examples where women in hairdressers have had a stroke laying back over the sink when having their hair washed.
                You will always end up with a crick in the neck looking up, at for example, the ceiling rose you are working on.
                There must be something in it as workers who work on ceilings lie on a mobile trolley and get moved about like that.
                Perhaps we need to invent a pair of 'Prism glasses' that allow us to look straight ahead but see upwards.
                #85587
                Weldsol
                  @weldsol
                  Hi Windy
                  I had the same problem I needed safety specs but I need reader lens to see close up when welding
                  so if you have reader grade safety specs to walk around customers workshops I had to either lift them up or have them low so I could see over the top . Not good for safety reasons
                  Bifocal gave clear top part and reader bottom still very hard to use .
                  So talked with my local optician.
                  I now have tri focal clear centre portion and reader part top and bottom.
                  So when welding I can look down and have the right focal length and when doing positional welding i can look up and still have the right focal distance.
                  It turned out he had done these before for a decorator who had the same problem when hanging wallpaper.
                  The cost = no more than a pair of normal perscription safety specs
                  Paul
                  #85589
                  KWIL
                    @kwil
                    They used to make "upside down" varifocals, in fact they worked both way, they were called "pilot" glasses because you could look up and see the overhead switch panels as well as looking down at the instruments. I wear varifocals all the time and agree looking upwards is a pain, but you have to cope. I would not be without them
                    #85590
                    Sub Mandrel
                      @submandrel
                      Over the last five years my eyes finally went through the middle-age shift. I was very short sighted, but could see right down to reading range with my glasses on. Now I have reading glasses and my long vision glasses, but the readers are so weak, I prefer to take my glasses off and hold what i'm reading near my nose! I got intro the habit of wearing my old 'computer glasses' all the time, which are in the middle and give me reading up to about six feet away -ideal for the workshop. But since losing these for a couple of weeks (found now) I've discovered that after a wile my eyes compensate so i can do computer/machining with my normal glasses at about 1 foot range – I'm typing now the screen is clear but the keyboard is fuzzy!
                      I thought that the cheap +2…+4 readers my wife uses (at a rate of about a pair a fortnight) would be a cheap and easy solution to really close work, but i'm so short sighted I can't tell any difference!
                      My big problem is the continual temptation to look over the top at what I'm machining – not a good idea, so i have three or four pairs of safety goggles spread even;y around the workshop.
                      I hate the idea of bi- or even vari-focals, but role on the day when they make adaptive spectacles with autofocus!
                      Colin Heseltine
                        @colinheseltine48622
                        I regularly have to work very low to the ground and trying to read miniscule serial numbers is damn near impossible, especially if in a poorly lit area. I quite like the idea of the trifocal glasses mentioned above, muist talk to optician.
                        Colin
                        #85600
                        Stephen Benson
                          @stephenbenson75261
                          As I mentioned earlier I use an Optivisor one with a number 4 lens for lathe work and another with a number 5 lens for close work these work well with my varifocal glasses. I am a clock repairer so I am wearing my one my Optivisors most of the working day if you have never tried these you might be surprised.
                          #85602
                          Roderick Jenkins
                            @roderickjenkins93242
                            These may help some of the problems outlined above: http://www.coleparmer.co.uk/1/1/14416-3m-bx-dual-reader-safety-glasses-2-0x-top-bot.html.
                            I just have age related long sightedness. I wear a pair of 1.0 dioptre glasses in the workshop with a pair of these: http://www.sportfish.co.uk/fly-fishing/sunglasses/magnifier-clip-on-flip-and-focus.html , strength 3, flipped down for close work. I find them more comfortable than a head magnifier.
                            cheers
                            Rod
                            #85603
                            the artfull-codger
                              @theartfull-codger
                              Hi Stephen, I've been looking for some sort of magnifier [it's my age!!!] I was looking at what appeared good quality headband loups with glass lenses from ''the loupe store'' after much ringing & emailing by my brother & myself they didn't even bother to reply so I'm interested in an optivisor, sounds just like the piece of equipment I'v been looking[he he] for.
                              #85608
                              Ady1
                                @ady1
                                eyesight problems…ass problems…hip problems
                                welcome to the problems club
                                I seem to remember David mentioning an old hand who worked on the lathes for years and when they gave him an eyetest he was retired as virtually blind, yet he was still turning out decent work
                                So don't give up too quickly
                                Edited By Ady1 on 23/02/2012 23:42:36
                                #85609
                                Mark Foster 1
                                  @markfoster1
                                  Hi guys Ihave a lens that goes behind the carterage on my welding helmet .it is great . ask at your welding shop I use a 1.5 a breath of fresh air for us older members
                                  #85610
                                  jason udall
                                    @jasonudall57142
                                    I too find myself taking my varifocals off for close work
                                    two things come to mind
                                    1 DONT WEAR CONTACTS WHEN ARC WELDING I am told even the slightest uv flash can'weld' them to your eye ball
                                    Hate the things anyway but….
                                    2 BRIGHT light helps loads…
                                    #85612
                                    Windy
                                      @windy30762
                                      Thanks for all the advice I will try to get a lens for the welding helmet that might be the solution for the welding problem.
                                      Windy
                                      #85620
                                      Martin Kyte
                                        @martinkyte99762
                                        Dont forget that you always have the option of getting different lenses for each eye. maybe bifocal for one eye and plain field at an appropriate distance for the other. You do loose some binoccular function but I am sure there are successful one eyed welders out there.
                                        Martin
                                        #85621
                                        john fletcher 1
                                          @johnfletcher1
                                          Regarding contact lenses and arc welding that was discounted years ago, we had posters made at work all about the claim then had to have them removed.Keep the helmet on,any flash is bad for the eyes.Ted
                                          #85626
                                          maurice bennie
                                            @mauricebennie99556
                                            Hi Windy. I have same problem .Have tried bi -focals tri focals and now have vari focals , all ,as every one says U.S, for looking up or laying under the car .I now have my varifocals plus a pair of reading glasses plus a pair of flip down head band type magnifiers .Plus ,and this is most important ,an extra strong light system, I know this is all a pain ,but its working for me .
                                            Hope this helps Maurice.
                                            #85627
                                            Ian S C
                                              @iansc
                                              A good number of years ago in ME there were letters aboutcontact lenses and welding, and they came to the same conclusion as Ted. Ian S C
                                              #85628
                                              Gordon W
                                                @gordonw
                                                I need glasses for all normal walking about things, but can read and see very small stuff without aid. Welding ,or any work under a car is hopeless, take them off to see detail, can't find the way out, roll onto glasses. I don't have a solution yet but a good light makes all the difference, the new LEDs are very good, might be to do with the wavelength/colour. Keep old glasses for work, new ones for driving etc. Will keep checking for any ideas.
                                                #85671
                                                Windy
                                                  @windy30762
                                                  I liked Marks comments of magnifier on the welding helmet cartridge.
                                                  As I have a cheap headband magnifier with some spares a lens was cut to length to fit the welding cartridge and taped on.
                                                  It looks good my vision has improved of the job.
                                                  Next is to do some test Tig welds at the weekend.
                                                  Thanks to the forum for another door has opened.
                                                  If you have a problem someone might have an answer if you ask.
                                                  A skilled engineer showed me the other week how to centralise hexagon bar in a 4 jaw self-centring chuck which was so quick and easy to do.
                                                  Something I thought you could not do with that type of chuck.
                                                  Windy
                                                  #85673
                                                  Anonymous
                                                    Posted by Windy on 24/02/2012 18:47:55:
                                                    Windy
                                                    Easy, just think about a coincident square and hexagon…… wink
                                                    #85686
                                                    Robert Miller 1
                                                      @robertmiller1
                                                      There is a product currently being advertised in the USA called Superfocus. Basically, it is a pair of eyeglasses that can be focused by adjusting a slider on the bridge between the lenses. They aren't cheap, but in theory they are a whole lot better than bifocals, trifocals, varifocals, or multiple pairs of glasses. They are also not too stylish – unless you are into the John Lennon look.
                                                      These are something I intend to give a try for my next pair of glasses, but right now the only Canadian retailer wants an additional $200 per pair, so I'll have to get the prescription and order from the US.
                                                      http://www.superfocus.com/
