Hi Dave
A well worthwhile improvement!
Remove the tailstock barrel , reverse it , and transfer it to the headstock chuck. The outer end can be put just into the mouth of the tailstock to support it. The process is then to cut lines onto the outside of the barrel with a suitable "V" pointed tool held in the toolpost. This needs a bit of thought but is really quite easy. With the tool on its side a line can be scribed along the length of the barrel for the distance you want the scale to be. For marking the divisions the "V" tool is held inverted with its tip in line with the line just inscribed. Advance the tool to the same depth as the first cut (above) then the circumferential marks can be made. The mark is made by rotating the headstock chuck BY HAND!
…….but how do you get the lines to be the right length I hear you ask!
This is with a bit of "Model Engineer's cunning!"…. so this was MY cunning plan! :-
I decided that I would have marks at 1/8 In intervals With a longer mark at 1/2 in and longer again at 1in. The length of each mark was determined by a stop. This was easier than it sounds. With a bit of trial and error – and using a pencil rather than the cutting tool! it looked OK. By making blocks of a suitable size and by arranging the position of the chuck and location of the barrel in the chuck I was able to limit the rotation by inserting the correct block to contact the chuck jaw. It worked a treat! All lines were the same depth controlled by the cross slide index and it was just a case of concentrating hard and inserting the correct block at the right time! When all were marked a light rub with some fine polishing paper removed the burrs and I then went over with a black wax crayon ( pinched from one of the kids art box!)
It would have been useful to have some numerals inscribed ….. but that was a step too far for me!
I would have liked to show you a pic or two … but I sold the machine and bought a Super 7 — which came with all those goodies!
Good luck – give it a go it's not hard and is very satisfying!
Norman
Edited By NJH on 13/04/2017 20:57:48
