These may have been relatively new machines when you used them!
They get a lot of use (I have two of them) but they are often lacking shear size. I do not have enough head room for a BP or other "full size" machine so I have to make do. They make up for lack of size in flexibility but a more rigid machine would be better for the work I do – it would be nice to be able to get stuck in with decent sized cutters but hey-ho, such is life. If I get an industrial unit (which might be on the horizon) I will get a decent sized machining center and then I will be sorted… probably also get some bigger manual machines as well for one off and modification jobs.
I also have a couple of Boxfords, and these are always "just" too small. I have worked out that that is always the case with machine tools so I must also put up with that.
Mark
PS. last weekend I was busy altering a 25mm steel plate from a 120mm diameter hole to 160mm (that is why the boring head is still on the mill) with a series of tapped holes around the perimeter (which also had to be faced square to the bore). The plate was 300 x 400 and I can tell you that is probably what you would consider as "too big" for these mills!
Edited By Mark C on 15/01/2017 12:41:16
