I am not going to labour this point, I would suggest that anyone doubting what I have said should google it! There are many sites out there that explain the difference in efficiency far better than I can.
Neils statement that "A bonus is that three phase motor produces constant torque at all points in its rotation, a single phase motor produces 'lumpy' torque, and that three-phase loans itself to electronic speed control"
Is getting near the point. If you consider a single phase sine wave, it passes through the zero line three time in a complete cycle, and at these points, no power is developed. In a three phase system, because the cycles are 120 degrees apart there is no point where the power output is at zero. If we introduce artificial 3 phase systems to the argument, we see the power consumed by the artificial 3 phase generator of whatever type lessens the efficiency of the whole system, although with modern equipment, not by much.
John Haine, I have read your second paragraph several times, and you seem to be in broad agreement with me apart from your statement that the slip creates the magnetizing current in the rotor. If slip was required to do that then a stationary motor being that the only motor with true zero slip is stationary, and would never start. The magnetic current in the rotor is induced by the field current which then attracts the induced pole in the rotor to the pole in the stator. as the rotor moves to try and reach the pole, the pole is already decreasing in power, and the next pole increasing, so that in effect the rotor never catches up, and the difference between them is the slip. As the rotor is loaded the slip increases marginally up to the point where the loading overcomes the torque, and the motor begins to slow. As you say, once this process has begun it is self destructive of the torque. The "shear" I was talking about was the initial point where the slip has increased to the point where the rotating field first becomes unable to drag the rotor round.. I think basically we are saying the same thing in different ways. For a more thorough explanation, see http://www.engineeringtoolbox.com/electrical-motor-slip-d_652.html
"There are complicated reasons why 3 phase motors are preferred" I would love to hear them! the simple reasons are that they are more efficient, more reliable and simpler to start.
I honestly didn't know about Brooks, I knew they had become Brook_Crompton which included many other companies as well, and also knew they were a Hawker Siddely company at one time, I will take your word for it, but if they are Chinese owned, they are certainly not shouting about it on their website. The problem with this type of takeover is that the resulting group eventually becomes so big that it fails, and is snapped up by the competition, usually foreign, who are simply purchasing a share of the market. Once the home industry is destroyed in this way usually by heavily government subsidised competitors from outside the accursed EU, then the market is supplied from cheaper places to manufacture (see John Stevensons post above)and the profit leaves the UK forever, along with the unpaid taxes that multinationals are so good at avoiding. It is ok to buy out, amalgamate or otherwise do a deal with your competitors as long as you are all in the same marketplace, you have the same costs and overheads. Foreign competition however, (especially when government backed) does not have the same costs and overheads as as UK based industries, and can therefire destroy the home industry at a stroke, then dump whatever quality and price it chooses to manufacture on a captive marketplece. Problem is without strict import controls on the QUALITY of goods, there seems to be no way back. So yes, it is good that Brooks are still in Huddersfield (for now), but I wonder how many of its motors are still made there, and how many are employed compared to what there used to be. According to my "Brooks Book" (1971) 3000 employees produced 500,000 motors annually.
Phil
