Electric motor question
Home › Forums › Beginners questions › Electric motor question
Viewing 23 posts - 1 through 23 (of 23 total)
  • #241339
    Robin Graham
      @robingraham42208
      I had a non-functioning Vax vacuum cleaner off Freegle today – the donor said it fired up intermittently on wiggling the power cord, so I thought it might be an easy fix. Not so, no amount of wiggling worked for me and I can't find anything wrong with connections or switches.
      I've stripped it down to the motor housing and there are three wires coloured blue, black and brown running from the switchgear to the motor. The blue wire actually runs directly from the power cord neutral. I've measured resistances and all combinations are effectively open cicruit (greater than 2 M-ohms).
      Any ideas? I don't actually need another vac, but I'm reluctant to tip it if it can be restored and passed on to someone who does. It's only a few months old, so it isn't wear and tear.
      Regards, Robin.
      #8145
      Robin Graham
        @robingraham42208
        #241340
        Paul Lousick
          @paullousick59116
          If it's only a few months old, it should still be under warranty. Have it replaced.
          #241343
          Robin Graham
            @robingraham42208
            The guy who gave it to me had it replaced under warranty but they didn't take the faulty machine back. I'm trying to make it work so I could give it to someone who needs it but can't afford to buy new.
            Rob.
            #241346
            John McNamara
              @johnmcnamara74883
              Sounds like the brushes are not connecting to the commutator?
              2 meg is almost open circuit.
              Maybe the commutator has a burnt out winding? you can test each opposite pole with a multimeter you should find the same resistance across each pair.
              You can test the field winding for open circuit.
              If you can wiggle the power lead it may be faulty?
              Did you test the lead from end to end. through the power switch as well.
              Steven Vine
                @stevenvine79904
                Have you connected a good known cable directly to the motor and fired it up, to take the other cable out of the picture?
                Steve
                #241352
                Colin Whittaker
                  @colinwhittaker20544
                  I agree with John, it smells like an intermittent commutator problem that may just need a bit of jiggling or spring retensioning to start working. It could also be a burnt out field or commutator winding, in which case a repair will normally be very problematic. If you are lucky then it may be the power switch.
                  Even with 40+ years of electrical experience I can still scare myself with live testing of appliances like this so I don't really want to suggest anything to someone with less electrical knowledge and quite possibly a weaker heart.
                  Cheers, Colin
                  #241355
                  Johnboy25
                    @johnboy25
                    Just a thought…
                    I bought a Henry vacuum cleaner at an auction with the same fault many years ago…
                    If it powers up when you wriggle the power cable – remove plug from supply and cut back say about 6" from the cable from the entry point. Remake the electrical connections inside the Vax. (It could be either the Vax end or plug end – replace moulded plug with an MK tough plug).
                    I've seen this manytimes in the past where the flexing of the cable breaks the conductor inside the insulation causing an intermittent fault. I experienced this on automotive sensors as well.
                    I have a name for this – I call it a 'rubber' joint!
                    Failing that diagnosis – check out the bushes. If they've warn down the retaining spring may have bottom out not providing contact pressure on the commutator.
                    daveb
                      @daveb17630
                      Broken flex is one of the most common faults on portable equipment, wire breaks inside the insulation at the stress point, usually where it enters the machine. Dave
                      #241385
                      Robin Graham
                        @robingraham42208
                        Thanks chaps, it is indeed a break in the neutral line of the power cable – in this case the internal cable clamp, which takes the cable through a tight 180 degree bend and holds it with three vicious prongs, had been over tightened. Strange world where it makes more economic sense to ship out a new replacement machine than fix a broken wire. It's been saved from a premature journey to the the tip though!
                        Robin
                        #241386
                        Vic
                          @vic
                          Our vac had a broken cable inside the moulded plug. A simple plug replacement fixed the problem.
                          #241393
                          NJH
                            @njh
                            Hi Robin
                            " Strange world where it makes more economic sense to ship out a new replacement machine than fix a broken wire"
                            Yes, on the face of it it would seem so – but then I got to thinking a bit……….
                            A quick search shows Curry's selling various models of Vax cleaner for around the £100 mark. Assuming yours was one of these Curry's must take a profit from that as must the wholesaler and the manufacturer – so the real cost of the item must be well below £100. On the other hand the cost of shipping back to the manufacturer, his diagnosis and rectification of the fault ( simple in your case I know – but maybe not always so) and the subsequent return to you will have to be taken out of the manufacturers profit. He will need to employ staff to carry out this work and they will carry overheads for his business ( and , down the line also for you.) In the mean time you will be without a vacuum cleaner! Much better that he sets up good quality control in his manufacturing process – which should ensure low levels of defect – and just replaces faulty items which should then occur infrequently.
                            When, after frequent and diligent operation in your hands, this Vax reaches the end of its life it will, no doubt, make an honourable exit to the local tip where it will be sent to be recycled into other "stuff" for our homes!
                            Norman
                            Edited By NJH on 04/06/2016 17:16:10
                            #241402
                            Mark P.
                              @markp
                              Maybe it’s time to go back to having engineers in a workshop at the back of the shop!
                              Mark P.
                              #241410
                              Muzzer
                                @muzzer
                                I doubt you'd want engineers at the back of the shop unless they'd been very naughty. Repair men perhaps…
                                #241448
                                Robin Graham
                                  @robingraham42208
                                  Posted by Muzzer on 04/06/2016 18:56:26:
                                  But they'd call themselves engineers I expect. The admin in University Departments used to be run by the Senior Administration Assistant, it's the Director of Business Administration now. But I'm feeling a grumpy old man rant coming on, I shall resist it!
                                  Norman, I'm sure you're right in your explanation of the economics. Apart from the motor and ten self tapping screws, the machine is entirely made of plastic mouldings, so I imagine the production cost is dominated by the cost of the motor. No idea what that would be, but I can believe that if I were to charge Vax a commercial rate even for this straightforward repair it might be cheaper for them to supply a replacement. Especially after I'd paid consultancy fees to you guys wink.
                                  To get back to technical matters, I think this may be a two speed motor – there are two (mechanically) latching switches operated by push-rods from the top of the machine. One is clearly the on-off switch (I don't have the manual), t'other connects mains live to the third wire into the motor. Would this be a second set of windings? Doesn't matter now I've found the fault, but I'm interested – always been a bit hazy on electric motors.
                                  Thanks again for advice, Robin.
                                  #241539
                                  Tim Stevens
                                    @timstevens64731
                                    One problem for the supplier running a repair service is his guarantee. How and where does he get certificated repair-persons, and then carry the cost of their inevitable failures including the houses that get burnt down?
                                    An automatic replace-with-new policy also avoids having to employ staff who know what a screwdriver is for.
                                    Silly old world …
                                    Cheers, Tim
                                    #241549
                                    Robbo
                                      @robbo
                                      The repair persons would be called "Technicians" and they would cost far too much to keep at the back of the shop in case of repairs under guarantee.
                                      In the days when repairmen were on premises, they also did repairs that customers paid for.
                                      Isn't it great going off-thread?
                                      Edited By Robbo on 05/06/2016 19:25:42
                                      #241713
                                      Dod
                                        @dod
                                        Don't get me started angry 2, I begun and spent 26 years as a Domestic Appliance Engineer angel, technicians are overcharging lowdown, guessing part pushing replacers, certainly not engineers.
                                        Wiggling the cable 99% of the time means, as suggested cutting a 6 inch (or metric equivalent) off one end and if that dont work off the other end. That way you can have a 2 foot cable and if it still wont work have a look at the brushes.
                                        Vacuum cleaner flexes break regularly as people try to do the extra inch before plugging into another socket
                                        #241896
                                        Robin Graham
                                          @robingraham42208
                                          Well, it's back together albeit with a cable shortened by 153mm wink. Quite a nice vac for the price I paid (zero), but I wouldn't want to part with 200 quid (asking price for this model) for it.
                                          When I put it back together I realised that it wasn't designed to be taken apart and reassembled – several of the self-tappers holding plastic to plastic couldn't be convincingly retightened. I'll find a way of getting it solid again I expect, but if anyone's been there before and can advise, that would be great.
                                          Robin
                                          #241902
                                          StephenS
                                            @stephens
                                            A good trick that I was taught many years ago works especially well for self-tappers into plastic, where the problem is that they will all too readily cut another new thread when reinserting them and after a couple of times there is no more material left for them to grip on to.
                                            Place the screw into the hole, and with the screwdriver carefully and lightly turn the screw backwards, or anti-clockwise. You will feel the screw drop into the previously cut thread, when you can tighten it in the normal direction once more. This means that you are screwing into the previously cut thread, not making another new one.
                                            Try it, it really does make a difference.
                                            Cheers, Stephen S.
                                            #241920
                                            Robbo
                                              @robbo
                                              Stephen S post is a good idea, have also used it for years.
                                              If you've already cut a second thread which doesn't grip well, fill the hole with some epoxy filler and insert the screw. The filler won't stick to the plastic but will fill the gaps
                                              #241923
                                              Andy Holdaway
                                                @andyholdaway
                                                You could put a small piece of strimmer line in the hole to create a tighter hole, then screw the self tapper in, just don't over-tighten it!
                                                Andy
                                                #242173
                                                Robin Graham
                                                  @robingraham42208
                                                  Ta for tips on reseating self tappers. Machine is functioning and the wife is well pleased – it's so light! I'm probably not going to dismantle it again unless I have to, but usef ul info for future use.
                                                  Thanks, Rob
