Drummond pre-B type lathe (1/4 scale)
Home › Forums › Work In Progress and completed items › Drummond pre-B type lathe (1/4 scale)
Viewing 25 posts - 1 through 25 (of 28 total)
  • #237291
    Ian Newman 1
      @iannewman1
      Hi,
      My new project is a 1/4 scale model of my own lathe – a Drummond Pre-B Type made in about 1910.
      One of the conical headstock bearings has reached the limit of its adjustment, so I had the headstock dismantled to take dimensions to make a replacement. While the headstock was demounted and in bits I took the opportunity to make fully dimensioned drawings of the parts for future reference – and one thing led to another….
      The obvious place to start is the bed. On the original, this is cast and to make a cast. Casting is not a process that I have access to, so I am going to mill/file the part from solid and fabricate some of the minor detail. Progress so far:
      As you can see, I've a long way to go with this component…
      Ian.
      #31129
      Ian Newman 1
        @iannewman1
        #237502
        Ian Newman 1
          @iannewman1
          Having frightened myself with the thought of trying to machine the bed, I decided to start with something a little easier.
          I spent yesterday evening flycutting some small slabs of stock to the desired thickness and then cut the 'blanks' that will become the compound slide, the cross slide and the saddle and filing them to shape.
          Compound parts:
          I machined the dovetails in the saddle, drilled and tapped the gib adjustment holes and filed the saddle to shape:
          #237508
          Philip Rowe
            @philiprowe13116
            Judging from the effort that you seem to be putting into this project I am assuming that you will be motorising this miniature Drummond. In which case you will have a very nice watchmakers lathe.
            Phil
            #237519
              Great project, Ian star
              Please keep the progress reports coming.
              Hopper
                @hopper
                Brilliant project! Keep us posted.
                #237598
                Ian S C
                  @iansc
                  Rather than an electric motor, would you not perhaps use a foot motor, although small open crank horizontal gas engines were a thing used by some.
                  Ian S C
                  #237603
                    Posted by Ian S C on 05/05/2016 11:42:23:
                    Ian S C
                    Ten he could set up a complete 1/4" scale sweat-shop complete and recruit a gang of toddlers to power it
                    neil
                    #237656
                    Tractor man
                      @tractorman
                      Very nice start on your project. So nice to see the machines we use being modelled. Keep up with the updates. Mick
                      #237911
                      Ian Newman 1
                        @iannewman1
                        Posted by Philip Rowe on 04/05/2016 16:12:34:
                        Phil
                        Phil,
                        As you (and Ian) have noticed, the intention is to make a working machine. I started on the assumption that it would be a nice, simple, straightforward project – it is a simple lathe with a total of about 12 moving parts, it must be a 'piece of cake' compared to a Gresley A4.
                        But when you start looking at the detail of the task it sort of grows
                        All the best,
                        Ian
                        #237913
                        Ian Newman 1
                          @iannewman1
                          Hi,
                          Today's progress – a bit of machining and drill/tapping to make the cross slide fit the saddle, and a little work with a needle file to shape the gib strip.
                          The parts (only one of the locating dimples has been drilled on the gib strip so far):
                          The cross slide fitted to the saddle:
                          Viewed from underneath:
                          The next challenge is to make a small Tee-slot cutter to produce the cross-slide Tee slots.
                          Ian
                          #237928
                          Ian S C
                            @iansc
                            Even with an electric motor, it should be run from a line shaft with a fast and loose pulley, same as we had at school running the old Herbert lathes (1920s vintage).
                            Ian S C
                            #238826
                            Ian Newman 1
                              @iannewman1
                              A bit more progress:
                              The feedscrew for the cross slide machined out:
                              I also cut out the cross slide front plate. After threading the feedscrew, the cross slide and saddle could be fully fitted with the front plate and feedscrew. A small handle was quickly filed up to allow the operation to be tested:
                              View underneath:
                              I also roughed out the headstock – milled/hacksawed from a block:
                              #238829
                                That's looking great, Ian
                                  Indeed a great project.
                                  #238909
                                  Hopper
                                    @hopper
                                    That's neat. Keep on posting. Loving it.
                                    #287925
                                    Benny Avelin
                                      @bennyavelin86238
                                      How is it going with this very interesting project?
                                      I have often entertained the idea of building a small machine, mill/lathe/shaper. If I would build one it would probably be a shaper and then I would make it large enough to be useful in cutting keyslots and such.
                                      #288763
                                      Chris Woodcock 2
                                        @chriswoodcock2
                                        This is indeed an interesting project and I also would be interested to know how it is progressing, particularly as I have two Drummond pre-Bs, one on an original treadle stand. When I needed to replace a small cast-iron component I carved a pattern in lime-wood and found a small local foundry (in Derbyshire). For a small charge they made me two castings which I was then able to finish off at home. Would this approach work with your quarter-scale lathe bed?
                                        #288782
                                        John Flack
                                          @johnflack59079
                                          Could Ian's real interest be in making large scale pens????????😈😈😈😈😈😈😈😈
                                          #291588
                                          Tractor man
                                            @tractorman
                                            Now there’s a possibility John lol.
                                            Did you see the million dollar coin that has been stolen from a museum in Canada. I could put that next to my lathe and kid you on it’s a miniature. If I had a spare couple of million to buy it that is. http://www.telegraph.co.uk/news/2017/03/27/giant-gold-coin-worth-almost-4-millionstolen-berlin-museum-dawn/
                                            #291589
                                            Tractor man
                                              @tractorman
                                              Ps how do I do links lol
                                              #291593
                                                Posted by Tractor man on 01/04/2017 08:04:32:
                                                Copy the URL [you evidently know how], then select this icon
                                                paste the URL into the box, and follow your nose.
                                                  Posted by Michael Gilligan on 01/04/2017 08:41:21:
                                                  And when the URL appears in the message box you can delete the 'http://' part to ensure it displays the destination instead of saying '**link**', or type something meaningful while the link is still highlighted.
                                                  Examples of the three approaches:
                                                  http://www.model-engineer.co.uk/
                                                  This Website
                                                  Ian Newman 1
                                                    @iannewman1
                                                    OK – boring things like earning a living got in the way of the model making for a while, but I've done some more on the bed
                                                    The outline has been roughed out now and the dovetails machined:
                                                    The base/foot of the bed will be fabricated.
                                                    Ian
                                                    #291626
                                                      Possibly a bit heavy to fly (it is an SE5a isn't it?)
                                                      Seriously, nice progress, it's very satisfying carving lumps of CI (if you don't make mistakes).
