A friend bought a Drummod M type yesterday, and would like to know what type of grease or oil should be used in the headstock. Also some of the gears are missing, particularly on the tumble reverse, are the gears the same as on Myford lathes 20DP ?
Oil not grease.
14dP 14.5 pressure angle not 20 / 20, pin drive not keyway.
Join this forum
learn to use the forum search engine to find dozens of previous Drummond topics
find Lathes.co.uk/drummond
join groups.io/drummond
join Facebook Drummond group if he can tolerate the teenage mentality.
Hi John I have sent you a message (you should see an envalope in box at the top of page in green band when logged on) about info that I have including a small handbook. Also I have an M Type lathe myself.
This is my tumbler reverse. You will struggle to get the small gears for it but there are a few members on the Drummond groups .io web site who occasionally make them. https://groups.io/g/drummondlathe have a look on there in the files section there is a drawing of all the parts of a tumbler reverse and other parts in the files section.
David
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
