Although milling in an ordinary pillar drill is generally considered an unsatisfactory, even dangerous process, the Fobco is designed to be capable of light milling.
Fobco bottom spindle bearings are an pre-loaded angular contact pair of the style common in milling machines and are well up to the loads. The screw on cap spindle is intended to take morse taper collets of similar style to those used by Myford giving both good grip on the cutters and minimal projection.
Its not proper milling machine tho'. Performance is limited by the relatively small diameter quill which is inevitably less stiff than that on a proper milling machine. The fine downed arrangement is little rudimentary and not as positive as that on a proper mill. I would hesitate to use one without the fine downed for milling duties. Although things will certainly work from the cutting perspective getting exactly the right depth of cut may be challenging.
It is what it is and certainly well up to handle appropriate sized milling cutters. In my view its best suited for jobs like spot facing, smoothing out faces and cutting flat bottomed slots or recesses where decent surface geometry and finish are the aim rather than precise depths. The pillar drill style depth stop is entirely adequate for jobs where 10 or 20 thou absolute error is fine. You'd need to work much harder to do significantly better on a routine basis. No substitute for fine downfeed really.
Were I intending to try more serious milling work I'd look into arranging a much more positive depth stop with integrated "display on a stick" depth reading device. I'd be unsurprised to discover that thou' or better depth accuracies could be achieved by working to a stop in this manner. Certainly the essentially similar arrangement I made for my square column Chester Lux style mill could achieve such accuracy. Making an accurate vertical cut on a Fobco would probably only be possible by setting the depth stop first. I found such work was doable but something of a faff on my mill but I'll not claim that my particular depth stop and readout system was the best that could be produced but it worked adequately with a fine down feed.
Extra table support is essential. Bottle jacks can creep and ordinary automotive scissors units are flimsy. Old style bevel gear driven vertical screw jack would probably be the most secure. Come up fairly regular on E-Bay or boot fairs. Ideally you'd want a finer screw thread.
Edited By Clive Foster on 12/04/2018 10:05:14
