drill chuck fitting
drill chuck fitting
Home › Forums › Workshop Tools and Tooling › drill chuck fitting
  • #286219
    Bob Stevenson
      @bobstevenson13909
      There are, as we know, two main types of drill chuck fitting;…threaded and tapered force fit…..
      I've looked on the web but can't find how one measures/determines the taper fit sizes, and the relevant numbering thereof………?
      it's time for my Aldi chinese drilling machine to gt a new (non chinese) chuck…the machine has done well over the last few years and well repaid the £30 or so that I paid,…however, the chuck has never pleased me and has to go now….
      #18434
      Bob Stevenson
        @bobstevenson13909
        Someone here knows…..please!
        #286227
        Ady1
          @ady1
          I just got a cheapo lidl version and it's a force fit with not much of a taper
          If you want to get it off then I would start by fitting a small milling cutter
          Then try some side milling, with no support under the tip for a few mm
          The vibration should free it up
          Have some support close under the tip, but not touching, to catch the chuck as it drops out
          gl
          edit: I wouldn't describe it as any particular size, it looked like the spindle fitted straight onto the chuck with mine, no taper
          Those units are cheap and built down to a price and any precision taper stuff costs money
          Edited By Ady1 on 27/02/2017 11:19:39
          #286228
          Benny Avelin
            @bennyavelin86238
            Little machine shop has this reference list for Jacobs taper, which I assume is the one.
            mgnbuk
              @mgnbuk
              IIRC my "no-name" Chinese pillar drill had a male B16 taper ended spindle. RDG (and others) sell B16 socket chucks. Again, IIRC, B16 is a stub Morse taper.
              HTH
              Nigel B
              #286235
              Bob Stevenson
                @bobstevenson13909
                The taper is decent on my machine (as is the rest of it) and the chuck is easy to remove by gentle persuasion with a mallet. I have clocked the spindle (taper) and it's more than good enough for making bits of clocks,….it's just the chuck letting things down a bit.
                Edited By Bob Stevenson on 27/02/2017 11:27:07
                #286238
                Bob Stevenson
                  @bobstevenson13909
                  Benny & Nigel,…thanks a lot!…that looks like it!
                  #286240
                  Jon Gibbs
                    @jongibbs59756
                    Posted by Nigel B on 27/02/2017 11:24:03:
                    +1
                    B16 is almost a de facto for cheap pillar drill chucks IMHO and is replacing JT6 in many situations.
                    Check out Wikipedia here for the dimension of B16 which is based on the small end of an MT2 here… **LINK**
                    Jon
                    #286309
                    Howard Lewis
                      @howardlewis46836
                      Details of Jacobs standard tapers are shown on page 3.5 of Tubal Cain's Model Engineers Handbook, 3rd Edition.
                      Issue 10 of the ArcEuroTrade Catalogue, Page 7 shows Chuck Removal wedges, covering JT1, JT2, JT3, and JT6, sold as pairs.
                      At the top of page 97 there is a comprehensive table giving details of Jacobs Tapers, 0,1,2 Short, 2, 33, 3, 4, 5 and 6, and then DIN tapers, B10, B12, B16, B18, B22 and B24 .
                      If your small drill press is anything like the Power Devil one that I use to own, the chuck shouldn't need much to remove it. Mine fell out!
                      Edited By Howard Lewis on 27/02/2017 16:26:36
                      Edited By Howard Lewis on 27/02/2017 16:27:04
