Price might make you think again, RA Baker do that size thread but with levers and they are £25 a pop so you would be looking in the region of £100 for a set if you could find them. I can only think of Stuarts who do the handle type.
Best thing to do is when you machine the taper on the spindles is to also machine a reamer or D bit at the same topslide setting which should give you a good matching taper that needs very little lapping.
These ones I did for the Tidman seem to seal OK
Used the same method for teh Fowler ones
Good write up on making teh Stuart type over on MEM
