Been offered the link above at £400 but again unsure
I am on my 2nd one of those – and only on the 2nd because I was given a complete new base FOC (right place, right time !) and bought a new head & column assembly cheap (again, right place, right time !) so had effectively a new machine for very little outlay. My original used one was sold to a friend for what I paid for it.
Pros : good capacity for footprint, easy speed change, head keyed to column, head adjustable to horizontal, ejecting drawbar, 2MT tooling
Cons : geared head not exactly quiet, short quill travel (40mm or so), no quill fine feed.
The column & head lift out of the base & the two parts are just about managable single-handed. Looking at the link provided the speeds are different to mine, but that may be a speed plate for 60hz motors. They have a fibre gear early in the gearbox that can shed teeth, so check that it runs OK. Both mine have slight X-Y squareness errors – the first one was a bit worse at about 0.003" over the Y travel (5.5" IIRC), while the current one is about 0.002". I have yet to get the scraper out to sort this. The bracket that holds the column to the base is adjustable side-to-side with grub screws & fore-and-aft with shims to get the column square. If you get a bit too enthusiastic with the feedrate the head can push out of true, but I only did this the once early on (too used to industrial stuff !). I use 2MT collets to hold cutters with minimum overhang.
The lack of quill fine feed isn't much of an issue – the quill feed has an adjustable depth stop & I usually work by bringing the quill firmly against the stop and locking it, then using the head feedscrew to touch off the top of the job. Release the quill clamp. retract the quill and move the job from under the spindle, apply required downfeed with the head leadscrew and clamp the head, then bring the quill back to the depth stop & clamp. As the head is keyed to the column, there is no loss of position moving it.
I have no regrets having bought this (these) machine(s) & will be keeping the current one regardless. I would guess that the reason they disappeared (this model was offered by many sellers at one point) was cost of production. I think you would struggle to get another machine as capable for the same money.
£0.02
Nigel B.
