I think mine was built from plans. The table just has 2 hefty T slots down each side so I need plates to mount some things on it. It's fitted with an early 1/2hp huge Brook's. My Peatol with a 1/4hp motor would cut through 3/8" mild steel plate with a 3/8 end mill on it easily. Also handle a woodruff cutter for 1/8 thick keys to full depth. I have used that on the miller.
When I bought it the motor was mounted on the rear of a plate at the back but being short of space that way I moved it to the front side and changed the belt length. It's offset to one side though making adjusting the angle of the head awkward. My jack for that is a bit of all thread with a slot in the end to suite the motor plate. I could do with something more flexible – maybe a longer length of all thread at an angle rather than vertical with spherical rod ends at each end but ideally it needs something better than that to allow full head movement.
There's a screw jack inside the column for raising and lowering the head –
The handle is on the wrongs side for me as it just clears the bench. That drives the jack via bevel gears. It would be hanging over the end of the bench if it was on the other side.
He ( probably) also made a rotary table and a dividing head. Both were well made which encouraged me to buy the miller. The rotary table casting had distorted a bit so the worm couldn't be taken totally out of mesh. It just about caught, thou's. When I relieved the casting a little it cracked. Still usable but an interesting factor concerning the quality of the castings from a certain supplier.
One "problem" with them is the draw bar, on mine anyway which is a 1/4 whit. When I buy fittings I buy the largest draw bar size and and some all thread to match. Drill and tap that and loctite it into the fitting.
It has one mistake that I am aware of. The drill wondered a little when the spindle was drilled for the draw bar. I should relieve it a bit at the socket end really but it doesn't really cause any problems. I'd guess the draw bar flexes a touch.
