Posted by jason udall on 15/11/2013 14:42:39:
Alan 204..at the risk of starting a flame war..
You indicate you specify and fit this species of pump for work..yet you ask what rating fuse.? Kwil suggests a "plumbing " solution..which might be simplest and at least readily tried..you dismiss this ( fine ).
Someone thought that the wattage of this pump is much lower than a "proper" suds pump , thus might not needs throttling down and you then seem to suggest that they are saying that its the other way round..
If you found yourself alone dealing with this I wouldn't be suprised.
Edited By jason udall on 15/11/2013 14:46:06
Jason I don't know where to start with this so forgive me if I miss out something,yes I fit lot's and lot's of Grunfos pump's for me they are the best on the market so that's why I said what I said, this forum has helped me out a lot since I joined it but being a beginner it's difficult to be much use to the member's so I thought I would say which fuse we use on different systems my way of trying to be helpful, I asked what size fuse Ray has been using only because his pump is pumping coolant or even oil for all I know so thinking it will have a higher viscosity it may put more load on the pump and need a bigger fuse. at the beginning of this thread I asked a simple question, will a dimmer switch work on a heating pump to which Kwil answered in a way that would suggest I asked a different question he's still crying about that it seems, as for the rest of your reply I don't have a clue what your on about.
Maybe you and Kwil should get a room and forget about this thread.
Your's Alan, busy playing engineering on my own, it's more fun.
