Dimensional errors in LBSC Doris drawings
Home › Forums › Beginners questions › Dimensional errors in LBSC Doris drawings
  • #171002
    Ricardo
      @ricardo
      Hi
      I am about to start construction of LBSC Doris.
      Would be grateful to know if anyone has a list of dimensional errors on the drawings.
      Thanks
      Richard
      #7388
      Ricardo
        @ricardo
        #171093
        Weary
          @weary
          Suggest that you try looking on this site:
          (You may have to join to use the site, but it is free, etc.)
          Some of the members have this locomotive, and at least one, username runner42 is currently building. I know that he has found an error in the regulator block.
          There is also an interesting series of posts on bringing the boiler up to date – with particular reference to meeting the current 'Aussie boiler regs'. (The site is run and administered by an Australian, and has a strong representation from that area.)
          Phil
          #171145
          stan pearson 1
            @stanpearson1
            Hi Richard
            I have built and still have a 31/2" Doris, I don't remember any real issues with the drawings but I have always used drawings as a guide only and check things before I cut. I don't remember problems with the regulator but it was a long while ago when I made it.
            Stan
            #171738
            J Hancock
              @jhancock95746
              I'm not sure if the law about burning witches ( heresy ) has been withdrawn so criticism of errors, or design flaws , has to be avoided.
              However, I would suggest you carefully go through the dimensions of the drawing relating to clashing of the rotating parts with stationary objects over the full movement ( up and down ) of the axleboxe and complete 360deg rotation of parts.. Connecting rods fouling slide bars or the bottom end of the expansion link . Coupling rods hitting weighshafts , or crossheads !
              Valve spindles not lining up with centre of expansion link , also eccentric rod connections well out of line with ' reality '.
              On the drawing these will all ' look good', only a careful check placing the drawing dimensions onto squared paper will reveal the 'truth'.
              Reading the write up of the day , end to end ,is useful and will include some errors , but not all !
              Even if you find no errors , the time will have been well spent.
