Die nut
Die nut
Home › Forums › General Questions › Die nut
  • #246049
    bodge
      @bodge
      Posted by Andrew Johnston on 09/07/2016 16:03:00:
      Here yer go; die on the left is 1-1/4" BSW, the other is 1-1/2" BSF, both 3" diameter:
      Hi Andrew they are split dies as im sure you know , Rainbows states Die nuts hex sided things for use with a spanner, used for cleaning up damaged bolt threads…………..b
      If you try cutting full thread with a dia nut they become split die nuts………b
      Edited By bodge on 10/07/2016 08:17:51
      #246050
      Raymond Anderson
        @raymondanderson34407
        Rainbows, Is this thread for your lathe spindle nose? If it is, then it really should be cut in a lathe. Although it's the register that governs the accuracy, I firmly believe the thread should also be cut accurately. If you have the means to single point it "partially " them you would also have the means to "fully " cut the thread, no need for any dies to clean it up as that can be done in the lathe. I have never needed or used dies to clean up any thread that i'm cutting. Having said that, we are all different and many would use a die to "clean up " others not. [ i'm one of the not's]
        Cheers.
        #246059
        bodge
          @bodge
          Posted by Michael Walters on 09/07/2016 17:10:03:
          Well the split nut clearly shows it could be cut. So the answer is yes, i reckon you could do it. Hasn't anyone seen the sort of dies used for pipe threading before, they're huge. (Now those are probably just for cleaning/repair) But i don't think a 1" Dia. thread with a coarse pitch is too big a push in 2 passes.
          Michael W
          Edited By Michael Walters on 09/07/2016 17:14:54
          Yes ive done stuff like that back in the days of iron pipes, diameter refers to the bore, threaded with pipe dies the big uns take a bit of turning on a manually operated die, the cutting teeth were inserts bit like a coventry die head but bigger, they never cut true concentric though, not much off just a few thou,( not good enough for what goes on here) but then they didnt have to be, just a bit of boss white and hemp to seal.
          I would screw cut on the lathe anything over 1/2 inch if possible…………b
          I see i havent quite got the hang of this cutting and pasting mularky yet !!
          Edited By bodge on 10/07/2016 08:56:50
          #246098
          Anonymous
            Posted by bodge on 10/07/2016 08:05:26:
            Oddly enough I did know that, and that die nuts are intended to clean up threads.
            In retrospect I don't know why I bothered posting; in future I'll use the time for something more useful. thumbs up
            #246100
            MW
              @mw27036
              happy days…
              Edited By Michael Walters on 10/07/2016 12:42:26
