We can be really lily-livered about depths of cut.
I just read a post where Jason recommended that someone takes a full 1/2" depth of cut with a slitting saw – sound advice.
I recently sawed two cuts through a tough steel on my bandsaw – a good 75mm of cut with no trouble at all with a nice wide kerf. Why do we blanche at much smaller cuts with a slitting saw when the mill is probably more powerful than the bandsaw?
Another example – how big a drill will you use on your lathe, or what step will you use between drill sizes?
I will happily drill 10mm diameter in steel with no pilot hole (split point drill). So why not use 10mm DOC, assuming a matching feed/speed can be achieved…? I doubt any of us achieve/attempt metal removal rates with a lathe tool that remotely approach what we take when drilling. Is it because drills are 'balanced'?
Or is it just that our typical tools aren't really ground/shaped for such heavy cuts?
