Thanks, a few more sources for me to investigate.
I think this would be a good place to demonstrate some good ones if i can find them. I promise i wont sharpen them so you can get an idea of how they perform "out of the box".
You see, thats the kind of talk that gives them a bad name, think of them as "old fashioned" and before the neat pristine world of carbide tips. I have used a good number of different tips and find on work loads the ones with the weaker support (like the push-on part off tips) and sharper edges don't stand the test of time. They either break/ jump out or the steel frame starts to burr and bend.
Theres an argument here for HSS as well, which i appreciate but thats got its own place of course, and i don't intend to talk about that.
The other thing that annoys me is the screws cam-out or round over quite easily, i did have an idea of using coppaslip to see if that might stop it ceasing.
There was a discussion on the practical machinist about this, and a well known member pointed out that it should be regarded as a complimentary system rather than competitive, which is basically what my collection is like, an assortment of all 3. He also said that if you imagine carbide like concrete, it's very hard, but if you have a very small sharp point, it's quite easy to chip because it's so brittle, hence, in order to cut well, they tend to have a corner radius to prevent that, and also a good reason why alot of them are negative rake to improve the life of the tip, because the heat resistance is almost limitless for our purposes.
All to play for, i think it should be given a chance.
Michael W
