Posted by Mervyn Karwot on 17/05/2019 15:17:33:.
… I have a 60v Pulse Width Modulator with Reverser and this would make the system more controllable. Are 60v supplies much more expensive than 48volt systems? I couldn't find much on the web, even from China….
That should work fine. Up to 48V switch mode supplies are cheap because they're used for LED lighting. Being a common standard voltage, loads of them get sold. 60V is uncommon and likely to attract premium prices, but they do exist. (£39)
Presumably your 60V PWM controller doesn't have a built-supply? If you can't find an affordable 60V unit, I'd be inclined to try it with a more affordable 48V psu. It should work, just slower.
Don't forget to mount the PSU inside a ventilated insulated box – those power supplies have open terminals and are far from swarf proof!
Good luck – hope it all works out,
