D1-3 Backplate Pins
D1-3 Backplate Pins
Home › Forums › Beginners questions › D1-3 Backplate Pins
  • #83616
    PeterB
      @peterb58166
      I was about to purchase a D1-3 backplate for my Denford Viceroy when I noticed that the Chinese (Chronos & RDG for instance) have apparently revised the pin size down by quite a lot! Why is this? Or am I mistaken? Would it still be safe to use?
      It appears the industry standard pin dia is 0.5937″ (19/32″ or 15.05mm). But pin sizes are now quoted as 9/16″ (14.27mm) or even 14mm depending on where you look. Moreover, it appears there are imperial threaded variants and metric threaded variants out there. That’s the thing about “Standards” – there are so many variants to choose from!
      Can anyone throw any light on this minefield please?
      Peter,
      #5911
      PeterB
        @peterb58166
        #83653
        Jon
          @jon
          Just had a look for you but n a D1-4
          An integral Pratt and Burnard is under by 6 thou.
          Elliot is bang, so is my TOS and chinese RDG back plate if that helps.
          It still dont stop the locking rings working to ‘O’ a common problem.
