Problem with neat cutting oil is the amount you need for a given operation.
I have my CVA on this and it’s fine unless I start drilling 3/4″ holes with a vengeance and then the place fills with smoke because I can’t feed enough on the keep the temp down.
Normal work is fine and the plus side of this is that it lubricates the lathe with no corrosion or worry about cleaning down.
I can’t run the small TOS on this because it tends to work for a living and that has gone onto soluble Cooledge.
So the problem I have is I’m running two types of coolant, neat and soluble depending on what machine it’s fitted to. If I was back to a smaller operation like a home shop I’d use neat and be aware of having to take it steady on larger drills and cuts. I does cost more. Current pricing at J&L for 20 litres of soluble Cooledge, which makes 400 litres is £64 a drum but often on offer at about £45.
Neat Ilocut is £57 a drum, again often on offer for about £40 but remember this only gets you 20 litres. Still probably worth it for the lack of worry.
John S.
