Crosslide backlash
Crosslide backlash
Home › Forums › Beginners questions › Crosslide backlash
  • #287260
    Paul Barter
      @paulbarter66156
      Hello all, I am gradually getting my Hobson H7 sorted, the runout on the spindle has been reduced to 0.0003" tir by an excellent local precision engineering firm who ground a new properly concentric register for a smaller ID taper roller bearing. The original bearing register was not on the same centre as its opposing partner, off by more than a thou.Although there appears to be little wear on the shears there is back lash on the crosslide, the brass 3/8 acme nut moves along the threads with about ten thou total "slop" when pushed to and fro. The threads on the lead screw look equal in width when comparing the ends of the screw to the middle,but the female threads in the nut look rather sharp. Can any of you wiser and experienced people tell me if this is normal or should a new nut be made, it looks pretty straightforward once an acme tap has been sourced. As I will probabably never need to cut another such thread I would like to be sure that a new nut is justified before adding another item to befuddle my heirs.
      Thanks in advance to anyone who responds.
      Paul
      Edited By Paul Barter on 05/03/2017 17:15:38
      #8598
      Paul Barter
        @paulbarter66156
        #287270
        daveb
          @daveb17630
          Yes, the nut is worn, a new one should have very little play. If you are buying a tap, make sure you buy the correct one, left or right hand as required.
          #287290
          Martin Connelly
            @martinconnelly55370
            It can be argued that cross slide backlash can be ignored because you only work in one direction when manually turning a part. Typical manual turning is done by approaching the desired diameter and measuring as you go to hit the desired size. Backlash will make no difference to this.
            Martin
