Copying on a Lathe
Copying on a Lathe
Home › Forums › General Questions › Copying on a Lathe
  • #25016
    Brian H
      @brianh50089
      Simple contour tracing
      #278759
      Brian H
        @brianh50089
        Are there any plans/instructions for a simple template type copying attachment for a lathe, preferably one that will make a reduced copy of the shape on the template?
        #278765
          Brian,
          You might find something suitable if you search for fusee making.
          pgk pgk
            @pgkpgk17461
            If just a one-off then I think it was tom lipton (oxtoolco) on youtube who demonstrated following a simple flat profile held in the tailstock with a pointer attached to the toolpost and manually followed. Probably one of hs 'baby bullet' vids but a quick look and I didn't find it
            #278774
            Hopper
              @hopper
              Or you can make something like a taper turning attachment but instead of the straight guideway for a taper, you use a template with a follower.
