converting radial arm saw
Home › Forums › Workshop Tools and Tooling › converting radial arm saw
  • #280479
    mick70
      @mick70
      planning on building fabrication bench using 1/2" x 8" steel slats drilled to take various jigs.
      to buy them cut to length is a no go due to cost.
      was wondering if could get metal cutting blade to fit my B&Q radial arm saw and use that by taking several light cuts each time?
      if so where is best place to get blade?
      #18378
      mick70
        @mick70
        #280481
          They snatch enough in wood hate to think what one would be like in steel so I won't suggest what type of blade may work.
          #280482
          Alan Waddington 2
            @alanwaddington2
            Are you thinking of using an abrasive cut off disc, or a carbide saw blade ? Either way I reckon t's a non starter,a decent bandsaw or guillotine would whip through those in no time, better to get the steel stockholder to do it.
            My local steel place doesn't charge loads for cutting, not compared to the cost of the material anyhow. 200 x 12 flat, won't be cheap especially if you don't have an account.
            Edited By Alan Waddington 2 on 27/01/2017 07:52:28
            #280483
            John Haine
              @johnhaine32865
              What do you mean my radial arm as the b&q site doesn't list these as such? You say 1/2" x 8" but how thick? I've seen that b&q stock rage blades for their chop saws that are suppose to cut steel IIRC.
              #280489
                1/2" thick x 8" wide flat bar cut to length was how I read it
                #280490
                  Posted by John Haine on 27/01/2017 08:14:11:
                  … You say 1/2" x 8" but how thick?
                  Interesting question, John
                  … I was about to ask differently: 1/2" x 8" but how long ?
                  Significant variations on a theme !!
                  Jason beat me to it.
                  Edited By Michael Gilligan on 27/01/2017 08:52:00
                  #280491
                  vintagengineer
                    @vintagengineer
                    Yes you can get a cold cutting blade for steel. But it depends on the speed of your saw as whether you can use you saw.
                    #280500
                    John Rudd
                      @johnrudd16576
                      My Rage cut off saw with 14" blade runs at 1450 rpm, my Rage 10" sliding mitre saw runs at 2500 rpm and the little Rage circular saw with its 185mm blade runs at around 4000rpm…..
                      I would not advocate using an 8 or 10" carbide blade for cutting steel in a mitre/chop saw not designed for that purpose….
                      #280526
                      Nicholas Farr
                        @nicholasfarr14254
                        Hi, if I were to be faced with this scenario without a suitable metal cutting saw, I would use a 9" angle grinder and thin cutting disc.
                        Regards Nick.
                        #280539
                        David Colwill
                          @davidcolwill19261
                          Whereabouts are you? It would be a shame to struggle if you were near to someone with a suitable saw. I'm in Nottingham if that's any good smiley
                          David
                          #280554
                          Alan Waddington 2
                            @alanwaddington2
                            I read it as wanting to cut 8″ wide x 1/2″ thick flat bar to lengths suitable to build a bench top, but who knows ?
                            #280559
                            Brian Oldford
                              @brianoldford70365
                              Posted by Alan Waddington 2 on 27/01/2017 12:46:20:
                              I read it as wanting to cut 8" wide x 1/2" thick flat bar to lengths suitable to build a bench top, but who knows ?
                              Me too.
                              Using a Radial Saw. FWIW My advice. . . .don't do it. If it grabs (as they do tend to) something is bound to let go big-time. I wouldn't want to be within shrapnel distance.
