Bill,
I also have had an FB2 for many years. It has proved an excellent buy; fine for light and medium milling, not quite rigid enough for really heavy work, but this is not a problem for amateur work as there is nothing you cannot do in stages. It also makes an excellent precision drilling machine. The only problem I have had is that several of the plastic cable glands have broken, but I have not seen the need to replace them yet.
I have the genuine Emco ER25/2MT collet holder and it is excellent quality, though rather expensive and probably hard to find now. I think many of the sets available today will serve well if you go to a reputable supplier; I suggest you look at
this set, I’ve been happy with the quality of tooling from this suplier.
Like Steamdave above my quill leaks oil slowly; it’s not a problem, I only need to top up the oil every 2-3 years. His suggestion about making the drawbar is spot on; I had a solid M10 Emco one supplied with the machine, but had to make a 3/8″ BSW one for some other tooling in exactly the way he described. It has worked fine for 25 years and shown no sign of coming adrift.
I have never felt the need for a spindle lock. Despite what the above-quoted website says, the Emco recommended method of removing 2MT tooling works fine and places no stress on the gears. You do need the special forcing nut to do it, but if you didn’t get one with the machine they are easy to make; ask here for details. It helps if you don’t pull the tooling too hard into the taper socket or it gets hard to remove – by whatever method you use.
The biggest improvement I made to mine was to fit a 3-axis DRO system (from Machine-DRO). This has transformed the accuracy of the work I can do.
David
PS – this website must be one of the flakiest I have used. I just typed the above and then it just jumped back to the home page and my words had disappeared; the back button revealed a blank box. Had to type it all out again. This is not the first time it has done this to me (perhaps it’s trying to tell me something!)
D
Edited By David Littlewood on 17/01/2012 15:39:21
Edited By David Littlewood on 17/01/2012 15:42:37
Edited By David Littlewood on 17/01/2012 15:43:59
