Posted by Ian Mellors on 25/02/2021 09:05:58:
Couple of questions Ketan, I'd PM these but the answers may be useful to others
- Is there any machining to be done to the collet chuck for the C1 lathe or is it a straight fit?
- are fixing bolts/screws supplied? – it looks from the images that there are 3 tapped holes, whereas the stock 3 jaw chick comes with studs that fit through the spindle plate.
Thanks
Hi Ian,
It is a straight fit (possibly tight) onto the chuck flange/back plate (Part 45) on this diagram
You will need a rubber mallet, to remove/fit the chucks.
Fixing studs are not supplied. 3 x Fixing holes are tapped M6 as shown in the details table on this page
Basically, the general 'Chinese Standard' for the back female register on an 80mm 3-Jaw Self-Centring (S.C.) Chuck is 55mm – to enable it to fit onto a flange/backplate with the matching 55mm male register. Also, most such chucks are tapped M6.
So, the ER lathe collet chuck registers and PCDs are made to conform to the Chinese standards of 80mm, 100mm, 125mm lathe chucks.
You may be able to unscrew the studs from your standard 3-Jaw S.C. Chuck and use them with your ER 25 lathe collet chuck. As far as I can recall, the studs would be introduced from the back of the flange, and screwed into the body of the ER25 lathe collet chuck, in the same way as your existing arrangement with the 3-Jaw S.C. chuck. Note: the stud does not need to go all the way through the tapped hole, as long as the studs go in a reasonable amount to hold the collet chuck secure in place, and you feel comfortable. Alternatively, you make up your own arrangement with studs and nuts to meet your needs.
Ketan at ARC
Edited By Ketan Swali on 25/02/2021 11:44:38
